Question about SanDisk Sansa m250 MP3 Player
Sandisk sansa m250 mp3 player gets stuck on USB reading data MTP on the screen(when connected to the usb port). The computer is not recognizing as far as I can see. there are no issues with the cord or usb port? What am i missing?
  • 422 Answers
In sansa, try look for 'storage mode' and switch it to 'mass storage'
Posted on Oct 16, 2013
SOURCE: SanDisk does not work
everytime i plug my sandisk or m2 adaptor into my computer,
it does not work at all, a little green light comes on but nothing else.
do i need a programme? can you tell me why i wasted my money on
buying this **** that doesnt work with my p.c.
Posted on Oct 19, 2008
DickCanFixIt
  • 948 Answers
SOURCE: problems connecting to the computer
You need to update your firmware first, then the settings menu will have the option to change the USB mode.
Get the firmware updater from here, under downloads on the right side of the page.
Posted on Jan 01, 2009
ipodslinger
  • 688 Answers
SOURCE: usb not recognizedon sansa e280
Your problem is not uncommon with many mp3 players, i am assuming your using Vista?
here is a link to Sansa that helps with this problem.
But before that I would try plugging your USB cord into a port on the back of the computer and preferably a usb 2.0 port.
If this doesn't get you connected right try this page for a solution.
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=yjPRdhzj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0yMzAsMjMwJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**&p_li=&p_topview=1
Good Luck and if you need more help let me know
Posted on Jun 01, 2009
bigpaws
  • 63 Answers
SOURCE: I have a SanDisk Sansa m250 MP3 player , when I plug the USB
it most likely dosent work on vista due to its age and or sansa never made a driver for vista. try sansa suport and look for drivers and downloads. there might be a driver there
Posted on Jun 23, 2009
SOURCE: My computer will not recognize my Sansa sandisk
My computer will not recognize my Sansa sandisk MP3 player. I tried to reset it, and when I get the "Please connect USB" message, it still won't recognize it.
Posted on Sep 05, 2009
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player: won't play any music or change to any other format...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ........
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
May 17, 2010 | SanDisk Sansa Clip MP3 Player
I need SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048) software.....
You can download the driver from the manufactuer's web site at http://www.sansa.com
Mar 14, 2010 | SanDisk Sansa m250 MP3 Player
My mp3 player does not recognized by computer, i want to load some music. how do i solve it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
STEP 2 - Check under Device Manager
STEP 3 - Refresh the drivers
SOLUTION 3 - Connect using MSC mode
for more answers at:
http://www.doremisoft.net/Sansa-Video-Converter-Mac/
or http://kb.sandisk.com/app/answers/list/
Mar 03, 2010 | SanDisk Sansa e250 MP3 Player
Computer does not recagnize MP3 player when connected
4. Power issue.
- Run the hotfix.
if u want more help u can go with these site:
http://www.doremisoft.net/Sansa-articles/Convert-video-to-Sansa-on-mac-osx/
wish above can help u solve your problems.
Jan 06, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Computer not reading
check to see if the media player has syncronization functions working and update drivers for MTP device as well as the media player. Check to make sure the hardware add indicates proper detection and not a yellow ? because it is only recognizing its usb.
Aug 24, 2009 | SanDisk Sansa m250 MP3 Player
Usb not recognizedon sansa e280
Jun 01, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Problem with my sansa m250
all three of you guys/girls have the same problem you dont have fast enough USB ports
~Temp
May 16, 2008 | SanDisk Sansa m260 MP3 Player
Stuck m230
to put your mp3 in MTP go to settings, and then to usb mode, then click in MTP, i don't know how to solve the rest of your problem, sorry, hope you find a cure
Jun 17, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
67 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
