Question about Hitachi CP-X1250 Multimedia Projector
Lamp temp on - Hitachi CP-X1250 Multimedia Projector
Why Lamp and temp lights come on after power up and stay on
You need to replace the lamp and then go into the settings menu and reset the lamp hours counter to zero.
Aug 16, 2014 | ViewSonic PJD6531W Projector
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
TV stopped working. Power light is blue, temp and
How long has it been sense you changed the lamp? This type of symptom seem as if it could be the lamp needs replaced. Check the manual for the lamp number. Make sure you buy an original hitachi lamp. I assume this is the brand. Hope this is helpful.
Oct 28, 2009 | Hitachi Televison & Video
My hitachi tv does not turn on the lamp and temp
Try replacing the lamp. Look in your manual to see what the lamp number is and search the net to find a replacement. lamps are not hard to replace, you can evern go to youtube.com type in how to replace a hitachi lamp and see a video. Hope this is helpful.
Oct 26, 2009 | Hitachi Televison & Video
Red temp and lamp light flashing
you may need to replace the lamp in the unit, to do so, remove the lamp and if it sounds like a rattle inside when you shake it, its blown due to heat ,hence the red temp and lamp warning. after replacing the lamp make sure you reset the lamp use hours. good luck.
Sep 26, 2009 | JVC HD-56FB97 HDTV
My Panasonic PT- 50LC13 doesn't turn on
Your service manual on page 82 steps you through decoding the blinking
1) there are two lights on the front near the reciever of the remote signals (Temp indicator and Lamp Indicator)
2) If the Temp indicator is on then they recommend you contact a service center
3) If the Lamp indicator is on and the power light stays on (no blinking) then you need to replace the lamp. Otherwise it says to contact the service center.
4) Counting blinks with the lamp indicator (1 every 5sec - lamp will not light or is abnormal, 2 every 5sec - lamp voltage is abnormal, 3 every 5sec - lamp temp is too high, 4 every 5sec - other error)
Apr 26, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Fault code sc542 appears on screen
The error code is related to the fuser area.
Likely to be a low fuser temp issue.
Need to verify good or bad heat lamps.
1) Check each lamp in fuser.
(lamp is good if you get continuity)
(lamp is bad if open)
2) Check the thermostat. (thermal control device)
(triggers if unit gets too hot)
3) Also check thermistor (monitors temp of fuser)
(2) total (middle and rear)
If heat lamp is good:
Your best bet is to change all three items. (Temp fix)
Fuser thermostat - thermal control device
Fuser thermistor (middle front) - thermal control device
Fuser thermistor (rear) - thermal control device
These items wear out. Change at the same time.
Fuser needs to be rebuilt or replaced.
(Check for wear and tear)
Inexpensive repair for the temp fix.
The whole Fuser cost can brake the bank.
I buy parts from precisionroller .com (you can preview the parts)
Franklin
baselinerepair .com
Apr 20, 2008 | Office Equipment & Supplies
Hitachi CP-X1250 Multimedia Projector Logo
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
