Question about Gestetner - DSM-616 COPIER Copier
Copier shows sc:552 on dsm616 - Gestetner - DSM-616 COPIER Copier
3 Suggested Answers
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
SOURCE: I have an error SC:120 Functional Problem
error sc120
Posted on Jul 24, 2009
What is sc 552 error code on a MP6002SP
Dirty fusing thermistor. Clean it, go into tech mode and turn off main power switch to reset it.
Aug 29, 2014 | Ricoh Office Equipment & Supplies
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
I HAVE A PROBLEM(errore sc-552) WITH MY COPIER Ricoh Aficio 2027 All-In-One Laser Printer
found this solution on line -Ricoh Copier Error Code SC 552 is Fusing thermistor error 2 problem
1. Fusing lamp is not connected angry.gif:(" title="Angry"> (reconnect it)
2. bent or is bad [img src="http://copierliquidationcenter.com/Copier_University/Smileys/default/angry.gif" alt=">:(" title="Angry"> (replace it)
3. Thermistor position incorrect [img src="http://copierliquidationcenter.com/Copier_University/Smileys/default/angry.gif" alt=">:(" title="Angry">
Try to reset this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
.... if this is not working, you might need new Fuser Thermistor ... go to Copier Parts Outlet.com find your copier, order your copier thermistor .... they have YouTube videos how to replace them too ...
Try this Video first:
youtube.com/watch?v=2S_jH3MOwr4
Jan 14, 2014 | Computers & Internet
Nashuatec dsm616 sc 544
more than likely to be paper wrapped round the hot roller - remove the fuser and split it - then clean the thermistors - should sort it
Oct 21, 2013 | Gestetner Office Equipment & Supplies
Codigo sc 552 ricoh 3800
SC 552 - Pressure roller warm-up error
Definition: After the main switch is turned
on or the door is closed, the
pressure roller temperature
does not reach the ready
temperature within 150
seconds during fusing unit
warm-up.
Possible Cause:
• Pressure roller fusing lamp broken
• Defective pressure roller thermistor
• Defective BCU
Troubleshooting Procedure:
1. Check if the pressure roller thermistor
is firmly connected.
2. Replace the fusing unit.
3. Replace the BCU.
Mar 01, 2011 | Ricoh Aficio 3800CMF Laser Printer
"A"
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Hie I have a Gestetner DSm615 which is giving me error code SC:552.How do i solved this problem?
Enter SP mode by pressing;
  • Clear (yellow) button
  • 1 0 7
  • Press and hold the Stop (orange) button for 3 seconds.
  • Switch off and on the machine.
If SC 552 (Fusing warm up error) appears again, possible causes are;
  1. Fusing thermistor defective or out of position or dirty with toner
  2. Fusing lamp open, and
  3. Power supply board defective.
Good luck and please rate me, thanks.
Power
Presure roller warm-up error.
Oct 27, 2008 | Lanier 1205 Copier
Gestetner DSM616
Turn the machine on, and press clear modes, 1, 0 ,7, and press and hold the clear stop key. It will beep, and a menu will appear. Select copy SP (1), and then select data log (#7) scroll until you get to 7807 (sc/jam counter reset). select it, and press execute. exit all the way out, and recycle the power. If it comes to ready, it should be ok. If it happens again after that, there is a fuser problem of some sort.
Mar 05, 2008 | Gestetner DSm616 Printer
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
