Question about Vehicle Parts & Accessories
Viper 300 ... no valet switch anywhere.. can put in valet mode with remote... how do I get the passive arming off..?? manual does not say....there is some way to do it with the remote buttons .. need to get into advanced programming mode #1 and change passive arming to off.. default should be off says manual.. disconnected battery for 15 seconds did not work..was not doing that when first installed
    Problem Solver:
  • 10 Answers
Google search the install PDF and it will give you an advanced options menu to turn that feature off. It's a bit confusing to do manual change but can be done. Your best bet is stop by an authorized viper dealer and have them plug in dei bit writer and change the option for you. They can have it done in ten minutes opposed to having to stress over the painful manual way of doing it.
Posted on Oct 17, 2013
SOURCE: viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
Posted on Feb 28, 2009
jmgldsmth
  • 2005 Answers
SOURCE: need instalation manual
http://www.directeddealers.com/manuals/OG/Viper/G3901V_09-2007_web.pdf
Posted on May 03, 2009
  • 53 Answers
SOURCE: Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
Posted on Jul 12, 2009
SOURCE: viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
Posted on Nov 16, 2009
richroth
  • 9472 Answers
SOURCE: I have a PR00E4BS 4-button
Here is a link to the programming guide for the remote Here is a link to the manual Here is a link to the installation guide
Happy Holidays
Posted on Dec 12, 2010
Where the **** is the Viper valet button?
Consider how the switch will be used before choosing a mounting location. Check for rear clearance before drilling a 9/32-inch hole and mounting the switch.The GRAY wire in the two-pin plug may also be used as a (+) ghost switch input and can be connected to any (+) switch in the vehicle. (See Feature Descriptions section of this guide.)
This is from the installation manual for the Viper 300. To answer your question, it is probably camoflaged. They only needed to tie +12vdc to the input line. What does this mean? Well, my best guess is, they are using one of your switches on your dash to act as the Valet function. Look for where the Gray wire, from the wiring harness of the Viper goes to: that WILL BE your hidden Valet switch. Best of luck!
Viper 300 ESP Installation Manual Plug in Harnesses Super Bright Led Valet...
Feb 15, 2016 | Remote Start System
Reset remote for a Viper 300 alarm 2 button 2 way to start my ignition no valet switch
If you follow this diagram, you should be able to locate your Valet switch. I have seen other questions like this and I believe that they have hidden the function by using an exsisting switch, seldem used(?), in your console. All you should have to do is eith tract the wire that comes from the port on the alarm modules body, or apply +12vdc to one of the leads identified for the valet function.
Best of luck!
Viper 300 ESP Installation Manual Wiring Quick Reference Guide
Feb 12, 2016 | Viper Vehicle Parts & Accessories
I have a 1995 ford f 150 truck with a 300 viper alarm the remote isn't working and no valet switch how do I bypass both to start my truck
In the wiring harness for the alarm is a Gray wire. Applying +12vdc to it will give the Valet function to you.
Best of luck!
http://www.manualslib.com/manual/755964/Viper-300-Esp.html?page=32#manual
Where does the black wire on the valet switch for a older model viper 300 12p pin ongl with gray valet wire
Hello Jesse,
I am not sure what kind of a valet switch that you currently have for replacement, however all viper systems use a two wire connector, with one gray wire and one black wire and a blue connector on the end. All this does when you hit the switch is series, or connect the two wires. The brain reads the number of pulses that is receiving the specified timeframe and then completes the command based on the set number of pulses. This connector is a separate 2 pin connector from the 12 pin main harness. This will be located when looking at the 12 pin harness on the right side of the brain.
Mar 06, 2014 | Viper Vehicle Parts & Accessories
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
I have had my Viper system for some years now with never a problem, that is until yesterday. Now when I arm or disarm my system the horn does not chirp and the small red dash light stays solid red instead...
Your alarm is is in valet. to take the alarm out of valet with the remote: open any door. Press lock, unlock, lock. The LED should be off now. Close the door and lock the doors with remote. The alarm should chirp to confirm that it is armed.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and lock the vehicle with the remote. The alarm should chirp to confirm that it is armed.
Nov 26, 2010 | Remote Start System
The alarm is on a 1996 f150 the alarm will not chirp the led on truck is solid it isnt blinking and it is a 5701 viper
Your alarm got put into valet mode some how
.It's easy to reverse out of it back to normal. First look for a small black push button under the dash somewhere. It's called a valet button. Here are the steps.
1. open door
2.turn key on then off
3.then within 10 seconds hit that valet button once(your alarm light should be off. Tell you arm it again. Then it will blink)
Hope this helps
Aug 18, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a viper alarm on my car that wont shut off nor i cant start the car..and i have tried the button under my dash, how Can i shut it off??
was it a professional or shade tree install? the following is off vipers website:
disarming without a remote control
This feature allows you to disarm the security system without the
Remote Control should it be lost, damaged, or disabled. In order to
disarm the system without a remote remote control, you must have
the vehicle’s ignition key and know where the Valet button is
located. Be sure to check with the installer for the location and the
number of presses of the Valet button required to disarm the system.
To disarm the security system,
turn the ignition to the ON position.
Press the Valet button the
preset number of times (one to
five times) within 15 seconds. After five seconds the system will
disarm. If the system does not disarm, you may have waited too long;
turn the ignition off and on and try again.
if that doesn't work try this other
valet mode
You can prevent your security system from automatically arming
and triggering by using Valet Mode. This is very useful when
washing the vehicle or having it serviced. In Valet Mode, the
security system will not arm, even with the Remote Control, but
all convenience functions (door locks, trunk release, etc.) will
continue to work normally.
To enter or exit Valet Mode:
1. Turn the ignition on.
2. Turn the ignition off.
3. Press and release the Valet
button within 10 seconds.
The status LED will light solidly if you are entering Valet Mode,
and it will go out if you are exiting Valet Mode.
May 08, 2010 | 1994 Honda Civic
I have a Viper 470v alarm and the keypad does everything it supposed to do as far as starting the truck locking and unlocking BUT it doesn't beep anymore and the screen doesn't reflect my status. It stays...
Is the red or blue light (LED)on the dash lit up solid? If it is then the alarm is in valet mode. 2 ways to take it out of valet. 1) open a door and press lock, unlock then lock again on your Viper remote. 2) turn the ignition on then off and press your valet/override button. The LED should go out and the beeps and status should come back. BTW you can also put the Viper into valet mode using the 2 methods above.
Feb 23, 2010 | Directed Electronics 479V Remote Gen 2...
Vehicle Parts & Accessories Logo
53 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
