Question about Refrigerators
I have a csx25grba wm. I have replaced the water inlet valves because it was not filling with water. it has been installed for about 2 weeks and only cycled maybe twice. that was with playing with it trying to get it to cycle. Now it has overflowed a lot during the night. I am thinking about replacing the whole icemaker assembly. It stopped with the fingers in the down position. Any thoughts?
    Sergeant:
    Champion:
  • 387 Answers
Your thought about replacing the ice maker has merit. I've seen them advertised for $50-65. It's worth the money, go for it.
Posted on Oct 15, 2013
dididsaythat
  • 291 Answers
SOURCE: ice maker water will not stop/overflows
either u got a bad ice maker or the spout going into the ice maker is leaking, ect.
Posted on Sep 03, 2007
SOURCE: Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Posted on Jul 14, 2009
mreid542
  • 166 Answers
SOURCE: My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
Posted on May 25, 2010
Testimonial: "Information was helpful. Now I need to find the water valve"
SOURCE: Icemaker water overflows into freezer
The problem is really that the GE icemaker WR30X10093 has a design flaw - there is a heating element located below the ice cube tray (which heats the tray to get the cubes out), but there is no guard of any sort below the tray. Since there is no guard below that heating element, the element heats ice that has accumulated near the element and starts melting it. Then, when the cubes are popped out, the partially melted ice re-freezes all the cubes together.
I have the same problem. :(
Posted on Dec 15, 2010
Sea Breeze
  • 4654 Answers
SOURCE: Replace water inlet valve for
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Posted on Dec 17, 2010
My ultima1000, wm 71 says error 10 sometimes and error 11 mid way thru a cycle. The pipes are fine and water is on what could be the problem?
E10 No cold fill detected - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
E11 Not hot fill detected - washing machine does not fill
  • Wiring fault
Apr 11, 2016 | Washing Machines
Ice maker that fills will water dispensed through refrigerator door.
the valve is probably operated by a celenoid, if you removed it during the hose replacement it may be installed incorrectly, out of line or not have a good ground.
Jul 12, 2015 | LG Refrigerators
Code ie machine fills with water but does not spin.
code ie + Inlet Error. Either the washer is taking too long to fill, or at least one of the inlet screens (usually the cold) is plugged. Turn off house supply valves so you can remove hoses from the back of the machine and then pull the screens out to clean them out. Replace the screens, re-connect hoses, turn valves back on and test.
Feb 07, 2011 | LG WM-2277HW Front Load Washer
I BROUGHT A BUSH WASHING MACHINE WM-1470TVE HAD IT 2 DAYS AND KEEPS COMING UP WITH Err5
Hi.
Err 5 is water inlet problem.
Move the appliance, ensure that the water hose is not kinked or blocked, and check filter in water hose if installed.
Check connected faucet and water pressure.
If the inlet hose and pressure is OK, then the inlet valve and water level switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Oct 29, 2010 | Washing Machines
Our LG Klasse front load washer won't turn on
check from power supply to the unit. If the controller is leeting the water inlet open and filling then the program must advance. If not the controller orr the valve can be faulty.
If the water fills and there is no response then check voltage to motor, check water level controller. If water inlet valve cuts off then the prrogram is advancing , check motor voltage, if absent check controller unit.
Sep 12, 2010 | LG WM-2277HW Front Load Washer
The frabric sofener and bleach will not empty in model lg wm-2277hw
This happened to mine about 2 years ago. I replaced the cold water valves/solenoids and this corrected my problem. The cold water inlet has 3 separate valves. One of the hoses that leads from it dispenses water into the softner and bleach sections "cups". I hope this helps, (I just got through replacing it "again" yesterday and one of the pumps that removes the dirty water out the drain)
Sep 06, 2010 | LG WM-2277HW Front Load Washer
Low water flow into washer. Rust-colored grit
Its normally held by two screws with a internay hose fitted to it should be quite simple o replace, make sure you fit inlet Filter too ,will stop dirt going into and damaging the valve in future, may be idea to get hot fill /feed tank cleaned....
Apr 06, 2010 | LG WM-2277HW Front Load Washer
The electronic cold water inlet valves at the top of the machine are leaking. My manual does not list the part and i need to replace it. I dont know the correct part name or number
Water Inlet Valve Replacement Procedure
Cold water inlet valve assembly: Part # 5221ER1003A
Hot water inlet valve: Part # 5220FR2006H
  1. Safety first. Unplug the machine.
  2. Close the water supply valve.
  3. Remove the cold water fill hose and drain the residual water into a pan or bucket.
  4. Remove the two screws on the back of the top panel securing it to the cabinet.
  5. Slide the top panel to the back of the machine and lift it off the cabinet.
  6. Disconnect the wiring harness connectors from the valves. Mark the connectors to make sure you reconnect them to the right valve.
  7. Unscrew the valve assembly from the cabinet and pull it out.
  8. Loosen the hose clamps and remove the hoses from valve assembly.
  9. Connect the hoses to the new valve assembly. Reinstall the valve assembly and the top panel in reverse of the steps above.
  10. Reconnect the fill hose and open the water supply valve.
Jan 26, 2010 | LG WM-2277HW Front Load Washer
THE WM DOESNT STOP FILLING UP WATER
It sounds like your water level switch is bad and needs to be replaced. The inlet valve opens and starts filling, and timer operation is suspended until the water level switch operates.
Jan 10, 2009 | Kenmore 24902 Top Load Washer
WM-14331FD filling with water
Replace the water inlet valve on the back of the machine that allows hot and cold water into the tub.
May 09, 2008 | Washing Machines
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
