Question about Supra Washing Machines
I need a spare part for a SUPRA Washing Machine model SW6B10FL I have broken the handle. Where I can find another one??? Thank you Franck My phone 00201226720869 My email lebaronnoir.soudan@gmail.com
    New Friend:
Supra washer sw5bh2p spin not working
Posted on Oct 27, 2013
bbtoast
  • 319 Answers
SOURCE: Whilpool washing machine model "Duet ht" fornot load
Press and hold the End Of Cycle Signal button
for 3 seconds to turn this feature off.
When the dryer is running and Control
Locked light is on, the dryer can be stopped by
pressing the Pause/Cancel button, but cannot
be restarted until the control is unlocked.
Good Luck, hope this FIXED YA
Posted on Jan 06, 2008
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
  • 82 Answers
SOURCE: hi my washing machine model bwm129 bearing has
Hi, most engineers would charge £90 just for the bearings. It's quite a big job.
Hope this gives ou some idea.
Posted on Sep 29, 2009
barkencoa
  • 3463 Answers
SOURCE: Broken door handle on washing machine
You can purchase any of the parts individually for the door handle.
If you go on line and enter Ariston door handle in search box, you shuold be able to locate the part/s you require.
Good luck.
Posted on Jan 06, 2010
  • 1244 Answers
SOURCE: An excessive amount of water is coming out under
the drain pump is probably cracked!! or the drain hose is lose or broken to the pump from the bottom of the pump! you will need to put the machine on it's side to check the pump and hose from the bottom of the machine where it hooks to the motor shaft
Posted on Jan 24, 2010
I have model 7411-900 is leaking from the bottom ? May i have to right video to watch to fix the leak and this part i found broken when try to find the leak
First you have to find the leak. First place to look is the pump and its hoses. Often there is a removable panel at the front, or a cut out section at the rear. Then check the door seal. Pull the machine out and tilt it back. Put something sturdy under the front so it doesn't drop on you.
Google
make model spare parts
and you will end up somewhere like here. Unable to tell what your broken part is, but wholesalers carry or can order all of them.
Washing Machine & Tumble Dryer Spare Parts & Accessories ' eSpares
www.espares.co.uk/browse/ca1236/washers-and-dryers
For Tumble Dryer Spares and Washing Machine Spares you've come to the right place. Give your appliance a new lease of life with our huge selection of ...
Washing Machine Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a11/Washing-Machine-Parts Washing Machine Parts - Shop online or call 800-269-2609. Fast shipping. Open 7 days a week. 365 day return policy.
Washing Machine Shop ' Partmaster
www.partmaster.co.uk/washing-machine-parts/catalogue.pl?path=66991 Find Washing Machine products - repair your Washing Machine with a Washing Machine ... Get the Washing Machine products you need at Partmaster. ... Over 1 million spare parts and accessories from the world's leading brands including ...
Jul 03, 2017 | Washing Machines
I can't find supra washing machine SW5C18 belt in UAE. BELT NO 1333 J6
MODEL NO SW5C18
Jan 23, 2015 | Supra Washing Machines
Lg washing machine model number.wd-10150tp door lock was broken need new door /lock&open handle spare parts
FixYa is sorry but this Forum does not supply parts, part numbers, prices or other details direct; it's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web. Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained on many makes and models, probably over many years ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 29, 2011 | Washing Machines
J845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 11, 2009 | Samsung Washing Machines
Cannot open door as handle broken for indesitw103
hiya easiest way to open is = first unplug power! then turn off water hoses to machine then draw machine out to gain access to pipe connections on rear and disconnect them ? now remove rear panel top screws as these also secure the top panel at rear then lift rear of top panel and pull to rear the panel now can be removed ? you now have access to the latch on front panel inside? if you reach down you can flick latch /hook clear to open door ? at this point after removing washing? you can observe the door inner remove inner panel that surrounds/secures glass? then you can observe how the door handle/lock assy is secured ? easy diy you can browse yellow pages for the replacement handle assy? machine repairs/spares reassembly is reverse to above wish you well this is a common occurance and should not have prob obtaining parts for the MAKE/MODEL NUMBER ? when enquiring for parts best wishes
Oct 21, 2008 | Washing Machines
Washing Machines Logo
Top Supra Washing Machines Experts
Andrew Taylor
Andrew Taylor
Are you a Supra Washing Machine Expert? Answer questions, earn points and help others
