Question about Whirlpool GR399LXHS Electric Kitchen Range
Glass top burner won't turn down - Whirlpool GR399LXHS Electric Kitchen Range
Tip
How to fix GE cooktop error code F116
First, i tried turning on/off power with no luck. if you get this code you will probably just need to replace the LF burner, which is pretty easy to do. i researched and found GE OEM parts from appliance zone. info is below:
ApplianceZone.com Items
1 Stove / Oven / Range Radiant Element Lf - WB30T10080 (OEM) @ $170.67 = $170.67
Sub-Total: $170.67
Shipping: $6.95 Standard Shipping (6.95) USD
ApplianceZone.com Total: $177.62
Once i received then new burner i just replaced it and all is working fine, no error code!
First i turned off all power and removed my cooktop from my counter and unscrewed the sheet metal shroud on the bottom, only remove the screws around the perimeter of shroud closets to glass, they are small black Phillips screws, like 15 screws total. i didn't disconnect any wires from the unit to junction box, you should be able to leave all that alone if you have a long enough connection. i made the mistake of leaving the cooktop upside down when removing the metal shroud, don't do this. there are springs on posts that keep the burners tight to the glass and will fall out (if up side down). leave the cooktop right side up and just lift off the glass once you remove all screws, when lifting the glass off, there is one plug at the circuit board attached to glass that you will need to unplug to completely remove the glass and set aside. you will see the 4 burners, i took a picture of the unit with glass removed to make sure i could reference any wires when i was re-installing new burner. i unplugged all wires to LF burner and unplugged the harness from the circuit board. once i removed old burner i noticed the new burner doesn't include the 2 tabs you need. i removed them from the old burner and made sure to install them in the same location on the new burner. I than plugged in all wires and harness back into the unit and set burner on posts with springs. carefully replace glass and don't forget to plug the glass top circuit board back into the unit circuit board. re-attach metal shroud and screws, drop in and done! there are instructions to re-calibrate the new burner which is probably a good idea, i didn't and it is working just fine! good luck
on Nov 16, 2013 | GE 30 in.JP950 Electric Cooktop
Rings won't come out around glass cooktop
I have had pretty good success with the green scratch pads
Mar 09, 2013 | Whirlpool Kitchen Ranges
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
I NEED TO REPLACE BROKEN GLASS TOP OF MAYTAG MODEL
ITS A LITTLE TRICKY, WHEN YOU GET YOUR NEW ONE LAY DOWN A OLD BLANKET PUT YOUR NEW ONE UPSIDEDOWN ON IT DISCONECT POWER THEN REMOVE YOUR OLD ONE .OPEN THE OVEN DOOR THERE IS 2 OR 3 SCREWS ON THE TOP OPENING HOLDING IT DOWN REMOVE THEM AND SLOWLY LIFT TOP UP AND SLOWLY PULL FORWARD. YOU WILL SEE A CONNECTOR TO DISCONECT ALL THE WIRES THEN LAY COOKTOP UPSIDEDOWN NEXT TO THE NEW ONE. SLOLY REMOVE SCREWS THAT HOLD BURNERS ON BRAKETS. I MARK THE HOLES ON THE BURNERS WITH A SHARPY
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 17, 2010 | Maytag MER5775Q Electric Kitchen Range
GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Jul 01, 2009 | GE Kitchen Ranges
Romvoing the top of my Whirlpool Cooktop
well usually you have to remove the knobs. thentake all of the caps off of the burners. sometimes there are scres that hold the burner caps on. make sure you turn the power off. Then after you have done this the glass should come right off. If not there may be screws under the cooktop. Do these first steps and let me know how it goes.
Jan 18, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Burner on glass stove top has turned black
The nice grey-flecked surface coating is very thin; the solid black is underneath. You've "cleaned" the coating off -- that's why further scrubbing just makes it worse. We did the same thing :-(
Dec 06, 2008 | Maytag MER5770 Electric Kitchen Range
Hi, my GE glass top oven has a bridge burner that won't work.
the bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Nov 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
Whirlpool GR399LXHS Electric Kitchen Range Logo
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
