Question about HP Pavilion Computers & Internet
Laptop charging problem - Pavilion HP Computers & Internet
  • 212 Answers
Check if there's a led on the power adapter and if yes, check if it's lit when plugged in.
if there is a led but it's not lit, the power supply is broken.
if there's a led that is constanly on, but the pc doesn't charge, it could be the battery (very common with HP laptops)
if there's no led on the power supply, remove the battery from the computer, connect the power and see if the computer works. if it does, the battery is broken and should be replaced.
if it doesn't, check the power connector to the laptop. there's a fine pin in the middle of the connector that may be damaged. if so, replace the adapter.
if not, it's still not clear if it's the adapter or the motherboard of the laptop and the only way of finding out which one it is, is replacing them one by one.
Posted on Oct 14, 2013
I have a new LB1 battery for my 2006 15 in.macbook pro it will not charge the test button on the battery shows it is full charge but will not turn on laptop or charge
The laptop is the problem and not the battery, check the battery contacts for corrosion or consult a specialist on how to fix your laptop.
Dec 10, 2014 | Computers & Internet
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
My toshiba P205-S6307 battery is not charging when plugged in
To test your toshiba p205 charger:
To test the laptop:
Jan 07, 2013 | Microsoft Computers & Internet
Battery not charging
Is it a replacement battery ,you purchased, with the EXACT same specs? Some aftermarket inexpensive batteries do not work well with your laptop. How do you know it's not charging, by the Icon in the Tray Notification Area? Again sometimes aftermarket batteries don't have the ability to communicate with the software. The pin-outs are not the same.
Dec 09, 2012 | Computers & Internet
Its plug in but battery wont charge
To test the laptop:
Nov 28, 2012 | HP Compaq nc2400 Notebook
Why will the battery not charge?
To test the laptop:
Nov 27, 2012 | HP G60-120US Laptop
DELL laptop isnt charging but power cord will keep it on why?
Jenni:
Your battery has died. You'll have to buy another one.
Nov 24, 2012 | Dell Latitude D630 Notebook
Power is plugged in , battery is plugged in not charging with 0% available
To test the laptop:
Replacement Acer Aspire 6930 AC Adapter 90Watt 19V 4.74A
Nov 12, 2012 | Acer Aspire 6930 6930g 6930z 6930zg Laptop...
Dell Xps 15 Laptop Battery Not Charging
To test the laptop:
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
Inspiron 6000-flashing battery light
Since you said the battery is not charging, why don't you remove the battery and charge directly to see if your laptop adapter will charge your laptop. Because i for see your laptop adapter been bad that is why it is not charging your laptop.
If it did not, it means your laptop adapter is bad and will need to be replace in order to charge your laptop.
Just change the adapter as advice and your laptop will charge.
Take care.
Apr 19, 2010 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
