Question about Raritan Computers & Internet
I have several Raritan UST1 units connected to a Paragon I KVM. We had a power failure a couple days ago. We have several units that will no longer allow us to login. When I power up a UST1, I am presented with the login screen however I can not get the box to login. I have tried the admin login with our original password as well as the default password with no luck. User account logins we had created won't work either. There doesn't appear to be any reset button on these boxes to do a factory reset either. Does anyone have any idea on how I can get the box to login? Tim
3 Suggested Answers
SOURCE: Cannot login to configure Belkin SMB KVM-over-IP swith
This happened to me until I installed the activeX control. Were you prompted for that, and did it install successfully?
After the activeX installed, did it also prompt you to install the secure certificate to access the site without IE prompting about invalid certificates?
Since you've tried multiple machines, I doubt security settings on IE are causing the problem. But my switch did these two actions before I was able to login successfully.
Posted on Mar 19, 2009
  • 4348 Answers
SOURCE: Hello! Me've got a Raritan Dominion
Look for a reset button, and press it for 30 seconds. that should restore factory settings, then default log in should work....
Posted on Feb 14, 2011
D2CIM-VUSB can use USB 1.0?
They should work, but I would use the PS2 connectors to be sure.
May 15, 2014 | Raritan Computer KVM Extenders...
I need rest i tried backside rest button but icant
Press and hold the reset button for about 20 seconds, it should reset.
Dec 27, 2012 | Raritan Computer DKX2-108-PAC - Raritan...
Raritan SW2USB. Has been working for several years. Today started normally, but suddenly the keyboard was not visible to the switch or either computer. Checked cables, rebooted, etc. Bought a new keyboard...
It sounds like the main switching IC on the board has gone bad...seen it happen before.
Your best bet is to replace it, I would check on Ebay for a good replacement a little cheaper than retail
Aug 20, 2011 | Raritan CompuSwitch CS2 (CS2-PENT) 2-port...
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
UMT242/USTIP2 not accepting remote clients, local only
I do not know this particular IP KVM but most IP KVM's use SIPPs that must be updated on the KVM when they are attached to the servers. Look for an option in the admin tools that say update SIPPs or update connection. You may also just have to double click on the list of connections to get it to update. This may have to be done at the console and not via remote.
Dec 18, 2008 | Raritan Paragon UMT242 (p2-umt242) 42-port...
Master Console II console lights keep blinking
Bernardo,
you said you tried disconnecting all of the Computers, did you check the MONITORS connection to the KVM? Perhaps it had gotten jarred loose.
Hopefully this helps you, if not please post a comment and I will try to further assist
Thanks
Dave
Nov 11, 2008 | Raritan Computers & Internet
ViewSonic VG900 and Raritan Paragon KVM won't play.
hi there, yes, go to safe mode first, then adjust the resolution to the lowest and restrat the unit. then you will boot up for a lower resolution and adjust it to your desire resolution. note that don't set it to higher resolution it will go blank again. ty
Feb 18, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Computers & Internet Logo
109 people viewed this question
Top Raritan Computers & Internet Experts
Mike
Are you a Raritan Computer and Internet Expert? Answer questions, earn points and help others
