Question about Fellowes DS-1 Shredder
The teeth are not turning it is just making a noise :(
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
Check the breaker,
Otherwise it may be a faulty unit. Contact Manufacturer for more details.
Posted on Oct 21, 2013
Motor(300) 6cyl.make bad and real loud noise starting now with motor running.this noise is not constant
Check and see if starter bolts are tight, if they are are tight you need to check flywheel bolts and teeth on flywheel. Sometimes starter teeth or flywheel teeth wear down. Could be the starter.
Nov 29, 2016 | Dryers
1995 olds achieva 3.1 liter v6 does the starter require shims its a new starter makes noise but doesnt start the engine
I'm not familiar with your vehicle, but I've never encountered a vehicle needing shims on a starter motor.
What may happen is the teeth on the ring gear - the teeth on the outside of the flywheel - become worn. The starter meshes with these teeth and spins the engine to start it. If the teeth are worn the starter cannot mesh with them and consequently, can't turn the engine over.
Because of compression the engine usually stops in the same position - the worn teeth are at the starter.
Try turning the engine by hand/with a wrench through 180 degrees so that any worn teeth are away from the starter, and then try starting it. If the engine spins - the fault is worn teeth on the flywheel.
Jan 05, 2016 | Cars & Trucks
EU 3000 si Honda electirc start cranks with erratic noise
It could be the starter making the noise.
If the engine is turning over, It could be the flywheel has some teeth broken.
Or the engine itself making the noise.
Try to isolate the source and go from there.
Hope this helps.
Feb 19, 2015 | Honda Cars & Trucks
My upright electrolux persicion vacuum when turned on just makes a horrible sound both on bare floor and on carpet brush does not turn
Hi, sounds like you need a new belt or brush and bearings . Sometimes when a belt goes it makes a bad noise as one of the belt teeth make be worn out. Hope this helps.
Jan 22, 2014 | Electrolux Vacuums
My gallant wont crank unless I keep trying for a while the starter turns but wont engage
There are a lot of things this could be and it is hard to tell without hearing the noise it makes. It could be the starter is not throwing the bendix far enough out to reach the teeth on the fly wheel. It could be the flywheel has bad teeth or the starter has bad teeth.
Oct 02, 2013 | Mitsubishi Galant Cars & Trucks
When I attempt to start my 89 jeep cherokee, it only makes a clicking noise, near the starter relay. Then occasionally it will try to turn over, but makes a grinding noise near the starter.
try to jump start it if it starts its the battery,if it doesnt than it time to remove the starter and go have it tested,while its out look for any worn teeth on the flywheel and starter solenoid teeth also.if starter comes back ok then look at all the cables,look for corrosion as it can hide under the wire sheilding.
Jun 26, 2010 | 1989 Jeep Cherokee
Won't start. Harsh grinding sound from starter
Starter has teeth that mesh with teeth on the flex plate . most of these type grinding noises are do to missing teeth on the starter gear or flex plate missing teeth .Does your vehicle have a automatic transmission ? Have you had starter replaced lately ?
Mar 31, 2017 | 2000 Oldsmobile Silhouette
Car starts but sometimes makes a whirling noise. I was told it was the starter
sounds like the starter is not disengaging the fly wheel quickly like it should when you turn the key the starter cog connects upto a fly wheel that has teeth all around it when the teeth of starter cog connect between teen on wheel it spins it to crank your car then goes back to starter if you hold your key on after starting the noise you hear is the starter cog(teeth ) still engaged in wheel if this is the sound it needs to be serviced not neccassarily replaced
Jun 06, 2009 | 2003 Chevrolet Impala
Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Fellowes DS-1 Shredder Logo
168 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
