INDESIT WIE167 flashing lights no error display all works ,, give it a bang they stop flashing .. but now they flash all through cycle anything going wrong ?
    Master:
  • 492 Answers
Stop banging your machine this doesn't work
Posted on Oct 15, 2013
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: indesit WIE167
Hi, and welcome to Fixya.
F03 is indicating that the wash thermistor is open or short circuit.
The thermistor is part of the water heating circuit,so the only thing you can do is to test the heating element for continuity or an earth fault..If faulty, replace.
If it is o/k then you will have to call an engineer.
Plz rate my solution.
Thanks, And a merry xmas.
Posted on Dec 22, 2008
barkencoa
  • 3463 Answers
SOURCE: Indesit WIE167 washing mashine
Remove the rear panel of the washer.
You will see the heater element at the rear of the drum,it has 2 wires going to it.
The thermistor as it is called is located at the end of the element,, unplug the connector on the thermistor. and pull the old one out, refit new thermistor, and connector.
Thanks.
Posted on Jan 06, 2009
  • 53 Answers
SOURCE: What does F-12 mean on the Indesit WIE167 washing
F12 - Communication error between main printed circuit boards. check connections.
Posted on Oct 29, 2009
SOURCE: wie167 flashes f-03 draw fills with water but
programator
Posted on Mar 01, 2011
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
The belt in my indesit WIE167 washing machine has come off and it is too tight for me to put back on, any suggestions.
You need to loosen the motor fitting or the pulley settings so that the belt can be place over the groove of the pullery and pushed forward so that it will fall into place.
If you use a small lever to wedge it will be easier to push it on to the pulley .
Place one end to the pulley and push forward.
Aug 20, 2011 | Indesit W 123 Front Load Washer
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
What does F-12 mean on the Indesit WIE167 washing machine? I have lost the manual.
Oct 29, 2009 | Washing Machines
Indesit 1600 WIE167 washing machine
locate element and remove you should then be able to remove bra wire they normally get caught around element
Jul 01, 2009 | Washing Machines
Thanks.
Jan 06, 2009 | Indesit W 123 Front Load Washer
Indesit WIE167
Dec 20, 2008 | Indesit W 123 Front Load Washer
Indesit WIE167 washing machine, displaying F03,
Error code f03 relates to the thermistor on the heating element.
This can be a faulty thermistor or bad contact between it and the control board.
Worst case scenario is a fault with the board which would mean a replacement.
Hope this helps & thanks for using Fixya
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
