Question about Kyocera FS-4000DN Laser Printer
Call service 7000: 0370082
I receive the service error above, does anyone know what this error relates to?
  • Kyocera Expert
  • 337 Answers
Toner motor lock error**The top cover interlock switch is damaged and the top cover actuator side does not always seat properly. Replace switch (part of switch regulator pcb) and repair retaining clip
Posted on Dec 26, 2013
Error c6704
Scanner image
processing board
(SCIPB)
• Memory control board /1
(MCB1)
• Overall control board
(OACB)
• Printer control board
(PRCB)
any one of the above boards$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ have tech come reflash the firmware first
Jan 23, 2014 | Konica Minolta Bizhub Press C6000 Copier
Webcam not recognised
You need to disable your other drivers that may disagree with this driver and then reinstall the driver and reboot (from device manager
....let me know if that work for you and please do not forget to rate my service so I am able to continue providing same...god bless
1 thump not related
2 thump related but no recommendation
3 thumps related worked some issues
4 thumps related worked all issues and satisfied
Oct 01, 2009 | Microsoft LifeCam NX-6000 Webcam
Receiving a beeping noise and error code of C:31:22
dear
the error is related to S REEL TABLE , which usually ocuurs due the amount of tension with
new tape , u can't solve this problem ur own .. u need to take it to the service centre as they will
do tape path alignment for the same .
Jul 23, 2009 | Video Cameras
Motorola Razr Bluetooth Error- Failed: Connection Interrupted
Some phone service providers block the transfer of files. It depends on who your service is through. I know Verizon and Sprint block them when I try to send from my phone to others with those providers.
Jun 06, 2009 | Motorola Mobility RAZR V3
Error message code 2,140,0
I had a similar problem (error Code:2,140,2) in Canon PIXMA MP250 all-in-one, and it was solved when I replaced both ink cartridges which were in low ink (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Mar 16, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Harman Kardon AVR 245 Receiver PROTECT Error Message/Shutting Down All Equipment
could be your receiver only, it has tripped due to discrepancy on the output stage of your amp. that cracking sound in one of your speakers could have caused the trouble. it is possibly shorted. but in your case it could have damaged already the amp that;s why it would not turn on. normally it will first trip, turn on then turns off. but to stay off and not to turn on again is major problem of the amp. or maybe it emanated from miscabling, probably the ceiling speakers got connected to a high output or main amp. but try removing all speakers first then turn the unit on. see if it does power up.
May 22, 2008 | Harman Multimedia AVR 245 7.1 Channels...
RX V670 Yamaha Receiver-No big display, No amplification
It is entirely possible that your display tube has gone on the fritz. We see it a lot...accordianman
Mar 19, 2008 | Yamaha RX-V661 Receiver
Canon ip6000d error like none other..
appropriate usually signifies that there's something amiss about the connection information either mechanically or electronically between the printer and the cartridge..I'd suggest you re load some drivers and see how that helps or does not?
Mar 10, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Service mode diagnostics error after repair
can be still the board that has been replaced has some boards can have faults from new but what can be wrong is that most motors have carbon brushes which go into the motor at either side of the motor with 1wire going onto them if these are low then the motor doesnt have enough contact with them so it wont spin properly pull these out and check first but be warned if the washer is under warranty you can void the warranty by letting anyone touch it m8 let me know how you get on and if no help then ill think what else it could be m8
Sep 12, 2007 | GE WPGT9350C Top Load Washer
Error 6A00 and my printer not printing
AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ass'y (QM2-1548)*1 Don't know it means but the service manual says the above
Mar 21, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Kyocera FS-4000DN Laser Printer Logo
170 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
