Question about American Standard Single Handle Kitchen Faucet with Sidespray 4175.203.002
Low pressure on side spray brand new amaerican standard part # 4175.203
2 Suggested Answers
packrat1948
  • 528 Answers
SOURCE: I have an american standard kitchen faucet with a
Check the aerator and see if it is getting plug up.
Posted on Feb 08, 2011
Low pressure
Bypass valve on pump is stuck. Not sure you can fix it but you can try to take the output side of the valve apart on the pump to clean it up or spray some silicone spray inside the output side of the pump. If this doesn't work you will need a new pump.
Jun 10, 2014 | Ridgid Garden
Diverter
Hi! Yes it sounds like the spray diverter needs replacing. Kohler .com will have this part online or you could try a plumbing supply shop.
Mar 29, 2014 | Kohler K-10413-VS Forte Single-Control...
I have a brand new moen muirfield high arc faucet with low pressure at spout but good pressure at side spray what can i do to get better pressure at spout
clevine336-
The design of a hand sprayer is meant to provide a higher pressure spray (the smaller outlet size means greater velocity in the water coming out of the sprayer head). That said, there could be something constricting the water flow in your faucet. If you unscrew the aerator on the end of the faucet do you get better pressure? Is the screen in the aerator clogged with sediment or mineral deposits? If this is the case you may have water requiring periodic cleaning of the aerator.
Hope this helps.
Regards,
DIYpro
May 01, 2011 | Moen Muirfield Kitchen Faucet with Side...
My heat pump has ice on it all the time what can i do
Hello
THis could be from the unit being low on freon or the pressure being to low,indicating a small leak.
Theres not much you can do about that.
You will need a service person to check the freon pressure.
What you can do is make sure the filter in side the unit is new and clean.Also shut down the condensor unit outside and clean it,simple green spray works good.Once youve sprayed it let the spray sit on the unit for a few,then rinse off with a hose.
This may help balance it back out.Also it may take a few min for the ice to go away,if it does not have the freon checked.
Jan 18, 2011 | Heating & Cooling
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
Sep 07, 2010 | American Standard Kitchen Faucet 6310 020...
Low pressure to the main faucet, great pressure to the side spray
try un-screwing the screen on the end where the water comes out. Could be clogged
May 01, 2010 | Price Pfister Marielle Kitchen Faucet with...
Low pressure,cleaned screen in tip,checked incoming supply,seems strong,yet pressure is low??
Has pressure always been low? If faucet is new than there will be a flow restricter in the aerator. Most flow restricters can be removed easily. Some are a pain. Have you tried checking the pressure with the aerator off. That would tell you if the problem is there or in the valve.
Apr 20, 2010 | Moen 7310 Legend Single-Handle Kitchen...
My weber gas go anywhere grill is alot more flame on the left side of the grill and the right side of the grill has very low fire even when turned on to high? p.s. the grill is brand new
Even a brand new BBQ makes a happy home for spiders. :)
1. Pull out the burners. Use a can of air or the equivalent to clean them out.
2. Disconnect the regulator from the feed hoses(if possible) Blow the hoses out. Check the regulator for obstruction (even a little bit of fluff, or a tiny spiderweb makes a huge difference) There will be a screen on one side of the regulator.
3. Reconnect and ensure connections are leak free. A soap solution sprayed on joints works well for this. Clean up soap solution thoroughly as some solutions can degrade piping.
***N.B. Do not apply a greater deal of air pressure to the regulator itself - it is rated for 1 - 5 PSI _AT MOST_ ****
Aug 05, 2009 | Weber Gas Go-Anywhere Grill
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
American Standard Single Handle Kitchen Faucet with Sidespray 4175.203.002 Logo
24 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
