Question about Xerox Phaser 6350DX Laser Printer
Printing Xerox Phaser 6350 without Magenta Toner
Have a Xerox Phaser 6350, and the magenta toner has been empty for a while. Today in the middle of a black and white print job the printer stopped printing, and won't print further because the magenta is empty. I have removed the magenta and shaken it, but it doesn't help. I've turned the printer off and on and tried to reset it. No help. Is there a way to get this printer to print in black and white with an empty magenta cartridge? (the organization can't afford the $200 or so for a new magenta cartrdige at this time).
  • leopold shanga Dec 12, 2012
    even mine thas what is doind it seems as if these printers has serious problems
    Champion:
  • 214 Answers
No get new magenta cart
Posted on Apr 24, 2009
Xerox phaser 6360 smearing magenta toner only
that's the developer assembly that has gone bad. If you're using 3rd party toner it wears down a lot quicker. You'll need to replace the magenta developer unit, part number is 848K03850.
http://www.iteminconline.com/848k03850_848k03850-xerox-6360-developer-assembly-magenta-oem-new-genuine.htm
Feb 09, 2016 | Xerox Office Equipment & Supplies
Magenta cart. wont print
The problem is most likely a bad Image Unit.
Xerox guarantees their supplies to be free from defects as long as their is a life percentage left and will replace it for free.
Take it back to the store you purchased it from and ask for a replacement, or have them request a replacement for you.
If the magenta fails (within 100 pages) after you replace the Image Unit, then your toner dispense mechanism is failing for the magenta toner, and either a dispense motor will need replaced, or the toner auger will need to be unclogged or replaced.
Jan 28, 2014 | Xerox Phaser 6360 Laser Printer
Xerox 6350 prints to much magenta
is it also when you print blank pages after the 25-50 pages? if so it could be the fuser, if not it could be the imaging unit. Check your magenta imaging unit and fuser roller anyway. If any of them is dirty, replace them.
Dec 02, 2013 | Xerox Phaser 6350/YDT Laser Printer
We have a Xerox Phaser 6350 and I was printing some copies today, when I looked over and it stopped printing magenta. So, I replaced the toner cartridge and opened the printer to make sure that everything...
Make sure you turn the printer off and back on a couple times. The fuser is not "hot-swappable"meaning you need to cycle the power for the machine to recognize it. If after doing this and you are confident that the fuser is seated correctly the next step would be to replace the fuser (part# - 115R00035). ItemInc.com has these in stock and ships same day. Hope this helps and thanks for using FixYa!
Aug 02, 2011 | Xerox Phaser 6350/YDT Laser Printer
My printer is pringting magenta all over the page. What should I do? I have replaced the imaging unit, fuzer, and the magenta toner cartridge.
zach,
We are having the same problem with our Xerox printing magenta. Did you every solve this? If so, what was the problem?
Thanks - Paul
Feb 03, 2011 | Xerox Phaser 6360 Laser Printer
Out of magenta toner, but need to print in black
normally most printers when you select properties and advance you can select the quality of printing there you can select grayscale instead of color that will do it
steps
click start printers right click properties for pinter select advance change the settings. print a test page will come only black if not repeat steps.
Jul 26, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 6350dp magenta flooding
Your Magenta developers are probably failing. Order 116-2009-00 and see if that fixes it.
Whit
Item, Inc.
Jun 15, 2009 | Xerox Phaser 6350/YDP Laser Printer
Phaser 6350 flooded with magenta toner
Problem developers start leaking toner. The problem is that some times the toner spuills into developers below it and damaging them. The problem may appear as a grinding noise that may indicate a developer gear/motor problem, when in fact its a bad developer that is not running smoothly. It may be expensive, and you may have to replace ALL the Developers.
Jun 15, 2009 | Xerox Phaser 6350/YDT Laser Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
Replaced Toner and Still Wants it to be replaced
You need to manually reset the CRU counter in the service menu to reset the toner count. This is designed so the xerox tech can come in and get paid for work. What you do is the following:
Enter the service mode by turning the machine off....then hold the (i) button and (<) arrow button simultaniously while turning the machine on. Then go down to nvram access enter menu, then go to CRU menu. Then go to the Toner CRU count menu, then select the toner you wish to reset and allow the machine to reset.
IF you need any parts feel free to come to my store
Andrew www.Getthatpart.com
Apr 23, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 6350DX Laser Printer Logo
388 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
