Question about KitchenAid 36 in. KECC568GSS Electric Cooktop
Blown fuse jed8430adb - KitchenAid 36 in. KECC568GSS Electric Cooktop
  • KitchenAid Master
  • 842 Answers
I would like to assist you but I am confused as too your model and fuse you refereed too. Is this a Kitchen-Aid or a Jen-air model?
Where is this fuse located? If I remember correctly in the Kitchen-aid model there was a single unit that had fuses with the harness and not on the lookup when you seek parts. But without more information I don't want to lead you down a goose chase.
Get back to me and I will be glad to help.
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Oct 18, 2013
Cooktop Model, Maytag JED8430ADB. When I tried to replace the Fan Control Knob, I accidently pushed the Fan Switch and Knob into the compartment below. How do I get the switch & knob back?
Hello, Thank You for using FixYa. I will be helping you today.You have to lift the unit up from the counter use some boards across the counter to support it and remove the screws from around the unit under the glass lip. On some units there are screws under the vent grille also. After removing the screws lift the whole top off.Thats all you have to do.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Jenn-Air JED8430 Electric Cooktop
I have a 4 burner Jenn-Air JED8430ADB electric radiant heat stove that has recently stopped working. It has been installed for many years (came with the house) and worked fine until now. When I turn one...
The cook top is connected to 220 volts. In the house wiring there are two legs each 115 volts. Usually they connect with a red wire, black wire and the third a neutral. It is likely that at the connection to the unit or at the electrical box a connection has failed or the 220 volt circuit breaker has failed on one leg. A qualified electrician needs to do the repair!
project1-nbbnxwvnfadegsi2zsme4jri-2-2.jpg Hope this helps?
May 04, 2017 | Jenn-Air JED8430 Electric Cooktop
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Sep 09, 2017 | Jenn-Air JED8430 Electric Cooktop
How do I replace the switch for a jennair electric cooktop? model jed8430adb. Thanks!
You first need to remove the unit from its installation. Start by disconnecting the exhaust fan from the ductwork. Then push the cooktop up.
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also at the top of the down draft cavity (the down draft cavity is where the grease guard mesh is)
Nov 15, 2009 | Jenn-Air JED8430 Electric Cooktop
Problem w/ plastic knobs on JennAir electric downdraft cooktop
NO METAL KNOB FOR THAT MODEL COZ IF USE METAL EVERY TIME U USE IS HOT THATS WHY DESIGN FOR PLASTIC,MUCH BETTER TO U REMOVE THE KNOBS AFTER U TUNN ON THE HOBS TO LESS MELT THEN RETURN IT IF U TUNR IT OR ADJUST.
May 17, 2009 | Jenn-Air JED8230 Electric Cooktop
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
KitchenAid 36 in. KECC568GSS Electric Cooktop Logo
103 people viewed this question
Top KitchenAid Cooktops Experts
vince
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
