Question about VDO PM290 Blower Motor
Replaced blower motor in 1997 ford e350 now I have air conditioning but no heat. does it have anything to do with the blower motor?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
I would look for a vac. leak of see if the heater coil is stoped up
Posted on Oct 15, 2013
1993 ford E350 club wagon has no air conditioning heater or blowing air
Could be the blower motor resistor or the blower fan switch or fuses check fuses first then move on try using a jumper wire to the fan motor if it works good if not its done do this from the + on the battery
Nov 15, 2017 | Ford Cars & Trucks
We have a 2006 Ford Van that when driving over 45mph the air conditioning will cut out. Any help is good help
there is a cycle switch. on the suction line that you can replace, see your local auto parts store.
Aug 31, 2015 | Air Conditioning and Heat for Ford E350
My 92 E350 blows cold air new water pump backflushed system but still blows cold air.
Check for stuck thermostat. Feel the heater core hoses to see if they are warm.
Oct 16, 2014 | Air Conditioning and Heat for Ford E350
Dashboard does not light up, blower for ac/heat does not work (I can hear vent move with controls) and high beam does not work.
verify blower motor is good? Blower motor stuck on high? you need a variable resister. A plug in unit near the motor. make sure that you install completely before checking. The resister need the air flow to keep it cool, you will burn a new one out in seconds if it is not installed in the case before checking.
Nov 13, 2013 | Ford E350 Cars & Trucks
1998 ford e350 air conditioning
Could be the PCM. It drives the AC clutch
Oct 16, 2012 | Air Conditioning and Heat for Ford E350
I have a 1994 Ford e350 club wagon van.When i start the vanand turn the heat on it stay on for approx mins then starts blowing cold ar. blower motor, blower motor resistor, thermastat,control switch have...
is your heater core hooked up, on most vehicles there are two hose on the left side under the hood that goes thru the fire wall if they are not there then that,s your problem bad heater core.
Sep 17, 2012 | 2002 Ford E350
1997 ford e350 21 passenger bus heater fan does not work
check fuse, check blower motor resistor in the plenum case or replace the blower motor.
Feb 15, 2011 | Ford E-350 Super Duty Cars & Trucks
No air blowing 1998 Ford E350
blower motor location is in the heater box down by the passengers feet the fan relay in out under the hood in the power fuse box check this first
check to see if the blower motor turns you can do this by removing the three screws the motor and squiral cage will come out spin it if it moves freely putit back replace the switch assembly
Mar 03, 2010 | 2002 Ford E350
Hi, My blower on my E350 1994 Ford is not working anymore... Where is it? Perhaps I can replace it myself. HELP !!!
i have a 2000 Ford E350 1 ton Van the heat works in front but blows cold air in rear. Would the problem be a blower heater switch and where is it? I hope I don't have to take off the whole dash.
Jan 28, 2010 | 2002 Ford E350
2003 ford van e350 rear air vent is not blowing
Try this article. I have the same problem and I think it is the vacuum motor that controls the door for changing from hot/cold in the rear heater box (located inside behind the L rear wheel)
https://www.fleet.ford.com/truckbbas/non-html/Q19.PDF
Jul 08, 2009 | 2002 Ford E350
VDO PM290 Blower Motor Logo
Top VDO Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a VDO Heating and Cooling Expert? Answer questions, earn points and help others
