Question about Magic Chef MCBR440 Compact Refrigerator
FAN MOTOR MODEL 5KCP39GGP.475S NEED TO REVERSE ROTATION
How to reverse rotation of single phase capacitor start motor
You have to reverse the coil (body) from the armature (center). Remove screws of your motor, armature is the center of the motor that rotates. Body is the part that has copper winding in the middle. Reverse this body and screw it back again. Try this and you will find that the armature rotates opposite the way you had it before.
May 03, 2017 | Heating & Cooling
How do i change the direction of the rotation of the blades on a model 52-DA? I understand it's done through the remote control but I don't have the instructions for the remote.
There may be a switch on the side of the wiring housing to effect reverse rotation. If the remote does not have a fan reversal button, it can't reverse rotation.
Jul 05, 2016 | Hampton Bay Dryers
Is it possible fan motor in freezer wrong rotation?
Yes if you have the wires reversed..motors run in two directions polarity is what it is called....need to make sure it is spinning in the in the direction the manufacturers set...some designed to pull sir and others push...good luck..
Jun 24, 2015 | Refrigerators
How to reverse motor rotation
What make/model of fan do you have? Remote?
Mar 27, 2015 | Dryers
How do I reverse the Hunter fan rotation with this remote control (PN 85095-01)?
you need to move the switch on the motor to change the rotation of the fan once you do it will work from the remote just when you need to change it back you need to move the switch again, good luck
Aug 08, 2011 | Dryers
Can not find directions to reverse fan rotation for summer
it should be a simple slide switch on the side of the housing that moves up and down to change the direction of rotation of the fan motor and blades. look at the manual that came with the fan to make sure it has this feature but i personally have never seen a fan without one.
May 30, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan is spinning opposite way
there should be like a switch to change direction of fan , if not then you need to change the wire connection , try that , AJ
Aug 13, 2009 | Ellington ROC52ALUM3LKRCR2 Rocket Ceiling...
Fan won't reverse to counter clockwise
I had a hampton bay fan that absolutely did not have a revers switch on the fan anywhere! MOST fans bought today will reverse. I was not about to give up. I scoured the net for an answer and could not find anything to help. I did however find a comment somewhere that said it could be done internally. After about six months I decided to search again (now). Nothing... so I started playing with the remote and the wall switch and Shazaam! I figured it out on my hampton bay fan. Turn the fan on high... Turn the wall switch off.... wait until the fan is pretty slow in rotation... hold the HI button on the remote.... Turn the switch back on. IT Worked for me! Hope this helps someone. SparqMark
Aug 10, 2009 | Hampton Bay 24750 Huntington III Ceiling...
My air conditioner fan motor runs in reverse thus, none or very little air is coming out
The fan motor can be wired correctly for up flow and still run backwards for downward flow or reverse when you put the wrong value capacitor or connect a hard start capacitor to an already bad start dual cap. Case in point: I come across a condenser where the fan motor is running (in the right direction, up) but the compressor is not. I put a hard start cap on the dual cap. The compressor comes on but now the fan motor runs reverse. No other wiring was changed. The hard start cap connected to the defective compressor start cap shifted the current, voltage phase 180 degrees to make the fan motor run backwards. I removed the hard start cap, removed the defective dual cap and replaced the dual cap with a known good one and everything worked correctly.
Jul 09, 2009 | Heating & Cooling
Magic Chef MCBR440 Compact Refrigerator Logo
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
