Question about Xerox WorkCentre XE80 Laser Printer
E7 error sub 05 - Xerox WorkCentre XE80 Laser Printer
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
What does error code e7 on a Dyson am 05 mean?
Hi there, it's Jack at Dyson.
If your Dyson Hot + Cool heater is displaying an E7 error code, we will need to take some further details via our Helpline to resolve this for you.
When you have your machine to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide assistance.
We'll look forward to speaking with you.
Oct 09, 2014 | Dyson Inc Am05 Hot Cool Fan Heater -...
E7 ERROR CODE
when the E7 code comes their is sub code u can view it by pressing start key then we can guest how ever i think this is coming from scanner ccd or chick ribbon cable connecting to the mother board from c c d
Jan 14, 2014 | Toshiba e-Studio 161 Copier Copier
Hi my copier displays E7
Check this out :
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the **** glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Oct 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to remove erro code E7
Code E7 has got sub-codes. Go and press copy button to see the sub-code and then report it. Generally, this concerns the laser unit and i would advice you to clean the optical platen glass from interior and screw back well. If a code occurs, then report it for more help.
Mar 09, 2010 | Sharp AR-5316 Advanced Digital Imager...
Copier turns on but will not copy
There should be a sub code for the E7. Depending on the sub code is what the error exactly is.
Jan 02, 2009 | Sharp Office Equipment & Supplies
E 7 sub code 20
the error code is E 7 - 02 cant find solution, help
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error E7
Hi, before i can help, you need to press the print button and it will show a 'sub code', which will determine the exact fault.
Cheers
Andy
Feb 22, 2008 | Office Equipment & Supplies
E7 problem
E7-02: LSU trouble
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
"1" key, "4"key
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
HELO
E7-00? = At initialization the white level correction cannot be completed.
You have to clean the white reference plate. Lift the Doc-Feeder, identify the white strip and clean any pen-marks or dirt!
BUT the rest of the code would help!!
  • E7 codes have sub-codes (read by pressing the ‘Print’ button)
  • E7-03 = "Laser Output Error"
  • E7-04/E7-05/E7-12 all refer to problems with the digital reading & laser output
  • E7-15 = Copy Lamp Output problem (doesn’t see the Exposure Lamp light)
  • Nov 19, 2007 | Sharp AR-5316 Advanced Digital Imager...
    Xerox WorkCentre XE80 Laser Printer Logo
    24 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
