Question about Kuppersbusch Cooktops
Kuppersbusch oven 2b error messages
I have a Kuppersbush EKI 607.1M and there ias a error E-13. i need know the problem Thanks Rui
What are BTUs for vintage propane oven/cooktop?
This is the only thing I can find on that brand. I would have thought your propane supplier could have given you the information?
http://kellysfuel.com/at-the-cottage
Or you could Google propane stoves and pick one that is similar. I won't make that much difference. Like this site
https://propanerefrigerator.ca/Propane_Range.htm
T. Burners
Oven
Broil
Height
Height CSH
Width
Depth
Oven
Broiling
Weight
9000btu
14000btu
14000btu
40"
35"
20"
25.5"
14"h x 16"w x 19"d
13"w x 13"d
110lb
http://wedgewood-stove.com/pages/reprint.html
Antique Gas Stoves Owner Manuals for Antique Vintage Stoves
Apr 24, 2016 | Cooktops
I have an EKI 807.2 Glass hob. I can't turn the heat up on more than one ring without E flashing on all the Rings followed by 6
Are you sure it is properly wired? For 1 phase 230v:
1= power earth
2-3 intersected = N
4-5-6 are L1-L2-L3 that should be conected together to L
Kuppersbusch is not very cooperative about what their error codes indicate, but E6 seems to be a (low) voltage issue, so you might too check the cabling to the outlet, measure the voltage with a multimeter when you successively switch on elements
Dec 22, 2015 | Kuppersbusch Glass ceramic induction hob...
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Hey, what can I do if on a ceramic hob there is no error message but a letter "L" at each section? The control buttons don't respond I only can switch off and on again but nothing happens. Please...
You've probably accidentally activated the child-lock "L". It would help to know which model you have as the deactivation method can vary on different models. However, this is the process for activation or deactivation on the EKI-848 which looks like the one in the above picture:
Switching off the childproof lock
1. Press the ON key.
2. Then immediately press the Plus key of the cooking zone at the left-back and the Minus key of the cooking zone at the right-back simultaneously.
3. Then press the Minus key in order to deactivate the childproof lock. The "L" will go off.
If this doesn't work or you have a different model, please post back and I will let you know the correct deactivation method for your model.
Hope this helps.
Regards,
BElectric
Nov 23, 2010 | Kuppersbusch Glass ceramic induction hob...
We have a GC2227DEDB fridge freezer it has a waterleak any ideas
geohgh -- GC2227DEDB Kuppersbusch/Maytag Refrigerator/Freezer - If in high humidity area then water condenses between the outer skin and inner skin. Builds up and then releases once surface tension limit is reached. Releases about 250ml to 500ml or more in some cases, directly onto the floor. Solution is to make or have made a Stainless steel tray to fit under the refrigerator. Motor heat then evaporates the water.
Sep 07, 2010 | Kuppersbusch K EGS 304.0 J Stainless...
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Cooktops Logo
37 people viewed this question
Top Kuppersbusch Cooktops Experts
Colin Stickland
Colin Stickland
Gil Shultz
Bill Boyd
Are you a Kuppersbusch Cooktop Expert? Answer questions, earn points and help others
