Question about Plumbing
Gould water pump - Plumbing
  • 3,368 Answers
Yep they make good pumps, what is your problem.
Posted on Jun 17, 2014
Goulds j5s pump discharging rusty water and green moss particles. how do i flush
If its discharging all the time, I would say its sucking up contaminated water but if only occasionally, that would suggest something is rusting / deteriorating in the system and it "grows" when the pump is not in use. I would have a close look at the source tank(s), the connecting pipework and as a last resort, disconnect the pump and have a look inside the pump chamber.
Jan 04, 2016 | Goulds Pumps Goulds 1/2Hp Shallow Well Jet...
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Why dont i have water pressure after my pump cycles off
Make sure your tank is well pressurized and not water logged.Is there a significant difference between your cut in and cut off pressure.Check for leaks -water or air.
Sep 07, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Why does my goulds pump j5s draw water to the pump but it won't pump out, what could be wrong and can it be repaired?
you will have to prime the pump after working on the lines. You can get just the pump section but I doubt that there is much wrong other than priming the pump
Aug 05, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Our goulds pumps j5s is running very loud after we replaced our sewage ejection pump last week. Could these problems be connected?
Those pumps last a long time. I do not think the problems are connected. I am assuming you are pumping water up from the pump. The pump has a check valve in the discharge that may not be closing. Cleaning that should solve your problem. Be sure water will pass through the discharge line into the drain.
Feb 05, 2014 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Gould water pump water pump will not shut off ,have replaced preasure stwich &GAGUE,HOLDING GOOD PREASURE
Does the switch click open, if so it is wired wrong. If not it is set to high.
Aug 15, 2013 | Goulds Pumps Plumbing
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
My water pump when reaches 40psi clicks on and off contineously
Pull the pump and check for blockage holding the foot valve open allowing the pressure to leak past the impellor back in to the water table. Sand --rocks are sucked up during the pump operation and will hold the ball off the seat.
Jan 27, 2013 | Goulds Pumps Goulds 1 Shallow Well Jet...
Well pump running every 5 minutes
It can be water loged you need to drain some water out of your tank and put 35 psi air in it,
Aug 27, 2009 | Goulds Pumps WW0511A Goulds Sewage Pump...
Plumbing Logo
35 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
