Question about Radio Communications
I have two LXT305(s) and they are about three years old. I ONLY use them during hunting season and when NOT in use the batteries are removed and the units are stored in my gun safe (DRY). One of the units is "hissing" with the RX display flashing on and off (mostly on) no matter what chanel it's on...or power. I put new batteries in it..and have tried EVERYTHING to get it to stop!!!!!!!!
    Scholar:
  • 97 Answers
The units receiver is "opening" this is either caused by a strong signal nearby or the receiver is failing (many of these radios suffer from bad capacitors) However you might get it to stop by setting a privacy code to "close" the receiver check the documentation to try setting a code this might get you by.
Posted on Oct 17, 2013
3 Suggested Answers
SOURCE: very bad hiss even when power is turned off and battery is removed
Hey I found The Problem .. The Phantom Power was switched to ON .. on the front of the Z1 Under the Lens.".. A big no no."
When I switched the Phantom Power off.. All clear again !!
Posted on Mar 11, 2008
eradiostore
  • 1654 Answers
SOURCE: I ptt and it immediatley 'roger beeps'
Beeping when you press the PTT button usually indicates a bad or weak battery. Check your batteries and charger. Clean contacts with a pencil eraser.
If you feel this is not the problem, then you have a radio problem. These radios are non-repairable, as parts and schematics were never released for them.
Best regards.
Posted on Dec 13, 2012
Power cuts when i turn key
If you mean everything goes out when you turn the key to the START position, understand this:
* Accessories will turn off during START to remove excess load on battery
* A weak battery will draw down and cause this symptom - the two most likely times of year are when it first gets really warn outside (batteries hate heat) and when it gets really cold outside (Natteries hate cold).
* A defective starter can draw excessive current and cause this symptom.
If your battery is more than three years old, I would suspect it first..
Nov 10, 2013 | Mazda RX-8 Cars & Trucks
Can I use electronic calls and electronic decoys to hunt game species during open seasons?
It is illegal to hunt waterfowl, wild turkeys or deer with electronic or battery powered decoys. It is illegal to use electronic or battery powered calls for waterfowl, wild turkey or deer. Restrictions do not currently exist for other game species.
Jan 17, 2013 | Hunting
Best regards.
Dec 12, 2012 | Motorola Talkabout® T9500 Two Way Radio
Motorola T6510 runs down battery quickly
these are one-way radios. no service, no spareparts. just trough away and buy new
Sep 04, 2012 | Motorola T6510 XLR Talkabout Two-Way...
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
2002 Big Bear 400. Dies after a few seconds upon startup
sounds to me the valves are not properly adjusted,..like their to tight,...i had run into this in a japanese car once,...check it out and let me know,.....cracklin joe
Jan 10, 2010 | 2002 Yamaha SR 400
Have a hoveround and it is three years old used one fall season and has been stored in a garage but won't start now
If you stored it for a long period of time (three weeks or more) the batteries have worn down and need to be replaced. These type of batteries must be charged at least once a week to maintian life in them.
Nov 14, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
Batteries discharge quickly even if the camera isn't being used. I have three batteries and two are over one year old.
Hi
It is recommended that if batteries are not going to be used for long periods they should be removed from the camera altogether during that time.
If you are referring to rechargeables the ability to retain charge is effected both by the age of the battery and the number of times it has been recharged.
Canon cameras are generally one of the better cameras in terms of being economic on power. It is likely that this problem is battery related and not camera related.
As it is also important not to mix old and new batteries together - I would recommend that you purchase new rechargeables. Three new rechargeables batteries in your Canon should resolve your problem and give the best results.
Thanks for using FixYa.
Oct 02, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
My etrex legend is also inoperative...
Inoperative as it won't turn on, or is there a line through the screen, or it won't recognize satellites?? We need a bit more information about 'inoperative'.
Have you downloaded and installed the latest software from the Garmin site? That might be a start.
Oct 25, 2008 | Garmin eTrex Legend GPS Receiver
T5000 have a lot of static!
I think if you can´t undestand what the other person is sayin, and you think is working fine, the problem could be at the speaker, check if the speaker is clear of dirty or sand or any thing that has not to be there. If you find any dirty or sand on you speaker, try to clean with a brush and giving some little knocks with a piece of steel Good luck
Nov 13, 2006 | Motorola TalkAbout T5000 2-Way Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
