The control board has shorted 3x's! Any suggestions to look for?
    Master:
  • 492 Answers
So eti es it's a cracked board
Posted on Oct 15, 2013
Element eldfw407 has blue screen only does not get menu or input screenswhat would cause this
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 10, 2015 | Element Electronics 40 Class LCD HDTV -...
My sony sxrd blinks green 1x then red 3x then it repeats red 3x..I have already replace the lamp can you help?
Blink's 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
Mar 09, 2015 | Sony Televison & Video
Demonstrate how to multiply two binomials
Try to seek these: By using the suggested format:
Suggested su
  1. Adding and Subtracting Binomials
    • 1
      Arrange each term in each binomial in order of degree from greatest to least. The degree of a binomial is the exponent attached to the term. For example, 4x^2 is a second degree term.
    • 2
      Multiply each term in the binomial that is being subtracted by -1 to turn it into an addition problem. For example, the problem (8x^2 + 8) - (x^2 - 2) becomes (8x^2 + 8) + (-x^2 + 2).
    • 3
      Combine like terms. In the example problem, the x^2 terms are combined and the constant terms are combined, yielding (8x^2 + 8) + (-x^2 + 2) = 7x^2 + 10.
    Multiplying Binomials
    • 4
      Understand the F.O.I.L. method. F.O.I.L. is an acronym standing for first, outside, inside and last. It means that you multiply the first number of the first binomial by the first number of the second, then the numbers on the outside (the first term of the first binomial by the second term of the second binomial) and so on. This ensures that both numbers in the first binomial are multiplied by both numbers in the second.
    • 5
      Use the F.O.I.L. method to multiply the two binomials together. For example, (3x + 4)(3x - 4) = 9x^2 +12x - 12x - 16. Notice that -12x is the product of the outside terms and -16 is the product of the last terms, 4 and -4.
    • 6
      Simplify. There will almost always be like terms to combine. In the example, 12x and -12x cancel out, yielding the answer 9x^2 - 16.
    Dividing Binomials
    • 7
      Use the distributive property to divide both terms in the binomial by the monomial divisor. For example, (18x^3 + 9x^2) / 3x = (18x^3 / 3x) + (9x^2 / 3x).
    • 8
      Understand how to divide by a term. If you are dividing a higher order term by a lower order term, you subtract the exponent. For example, y^3/y = y^2. The number part of each term is handled like any other division problem. For example, 20z / 4 = 5z.
    • 9
      Divide each term in the binomial by the divisor; (18x^3 / 3x) + (9x^2 / 3x) = 6x^2 + 3x.
May 10, 2014 | Computers & Internet
Have Duet front load dryer. When pressing Hold/start button, hear 3 fast beeps from the back of the unit, display flashes and dryer will not start. Any suggestions?
This is a common problem with the Duet and the solution is to replace the Motor Control Board (MCU). The control board has a short and the new control boards are revised to address this issue. Here is a link to the new control board.
Here is a copy of my service manual to help you replace the control board.
Good luck and keep me posted.Richard Roth
Oct 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My camera would not turn on
Assuming batteries are good, the problem is the system control board that controls the entire camera, and is a job for a camera technician.
Jan 14, 2011 | Kodak Easyshare V1233 12.1MP Digital...
Power off even when battery are new or fully charged
If the battery contacts are good and clean then the problem is within the camera. you will need to remove the camera,if there is good tools and experience, to see if there is any failure of the power to the main control board. If the power is coming in to the main control board then the fault is inthe board and the possibility to repair is low. you may have to replace tthe board for which the services of Kodak will be needed.
Oct 03, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
45 Pint Capacity, Electronic Control - 115 volt Dehumidifier HDN455E - No power
Check the fuse on the board. If the fuse is ok
check Zener Diode ZD2 on the board to see if its shorted.
If it's shorted replace.
Aug 07, 2008 | Haier HDN455 Dehumidifier
KV- 32V40 Fusible resistor always blow-up
hey...glad im not the only one in this mess....thank god i have an electronics background as i my offer some help. i found that Q601/Q602 were shorted,replaced with NTE2582 transistors, but also there is another fusible resistor located next ti the transformer on the powersupply board(board G i believe)same as the other(1/4-1/2 watt .1-.15 omhs)well i thought all was well until i pluged it in and both fusible resistors and the transistors blew right away....led me to the H-OUT transistor, right next to the flyback, on the main board...sure enough it was shorted as well. that part is 2SC5148(not the NTE part #), , and will put it in after work tommorow...looks good so far and will, even with my mistake will cost several hundred dollars less than taking it to a tv shop...and thousands less that the plasma screen the wife wants....this 32inch has been good to me for 9 years, and im going to help it along for another if possible. you cant email me at kellysheros@aol.com if youd like.....thanks and good luck
Nov 06, 2006 | Sony KV-32S26 32" TV
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
