Question about Lexmark X5250 All-In-One InkJet Printer
Paper is not running
Suddenly the paper is not running , there is no old paper inside , 2 minutes ago it did work normaly(there is enough paper on the printer)
  • 55 Answers
Paper pick up roller have problem.
you can clean it ,and change or go service center .
Posted on Apr 24, 2009
Have an exellent used HP 8100 printer in home for private and at-home work use. Replaced paper pickup-up assy less than 1000 pages ago, fuser six months ago. No other obvious problems. Just a couple weeks...
hi warren,
If you can open the printer and detach paper assembly a while then put it back firmly,then also the fuser assembly..see to it that no other particles or foreign materials inside the printer and all were aligned.
Hope it can give you idea.
mastergani
Jan 27, 2011 | HP LaserJet 8100 Printer
My Zebra printer is eating labels on and off. I feel when the printer runs out of labels it losses the labels and never prints it again when the Labels are reloaded. Is there a configuration setup for the...
is possible calibration issues. please run manual calibration,
go through the setings and run MEDIA and RIBBON CALIBRATION.
if ask to load labels,
open printhead, take 2-4 labels from the back papel and load the back paper normaly.
then press enter. Ask for REMOVE RIBBON? open printhead and move the ribbon from left to the rigth of the printhead (remove from the sensors(left and side)) press enter.
let the printer save that figers from the sensors (back paper/no ribbon)
LOAD MEDIA?
ok, put all back on normaly (labels and ribbon set up proply) press enter.
The printer going to run the calibration, if stop on the gap?! save (press twice on SETUP Button.
SAVED? OK. turn of and turn on again, send the job.
Hope help. Rate please. Thanks.
Dec 17, 2010 | Zebra Z4Mplus Label Printer
My printer is saying that there is a paper jam but there is nothing in there. what can i do?
there a small plastic sensors on paper path, normaly you have some sensor stucked.
you can check all paper path inside printer, there is a paper door nearby power input. open-it and locate the sensors small plastic finger check for free mooving operation.
normaly is one of three sensors (one for no-paper, 2nd for middle of paper path and one for paper position nearby print-head, test path with a paper, for free path.
Dec 11, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Paper loading problem
try buying a new **** of paper 20 lb weight. if the paper has been sitting around a while believe it or not humidity levels can affect it. If this does not work I would start looking inside the printer to see if anything is stopping the paper flow.
Oct 17, 2009 | Dell 926 All-In-One InkJet Printer
Espon 1400 prob. with vista close the cd/dvd guide. It is CLOSED!
I am having the same problem. I am on my 3rd printer from Epson in 2 weeks.
The solution may be to buy another brand, but I have more in Epson ink & paper than I have in the printer.
Jun 04, 2009 | Epson Stylus Photo 1400 Printer
Paper mismatch error
GO ON LINE AND TYPE THE FOOLOWING INFORMATION:
HP C5580 PAPER MISMATCH ERROR
ENETER
TO SEE IF ANYONE ELSE HAS HAS THIS PROBLEM AND MAYBE HOW TO SOLVE IT, IT IT IS A RECALL ISSUE, THERE AGAIN DEPENDING HOW OLD THE SYSTEMS MATTERS.
May 09, 2009 | HP Officejet 4315v All-In-One InkJet...
Recurring false paperjam alert
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | HP LaserJet 4100dtn Printer
The paper won't advance enough to print in our HP officejet 7580
Look for little pieces of paper that get stuck in the rollers, also verify that the gears and roller didn't get misaligned when you cleared the jam.
Good Luck,
Mar 02, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper intake problems
Once upon a time . . .
This problem was quite common and HP even designed a fixture (mine is history, along with printer repair in general) that was placed in the paper intake and simple software caused the printer to grind away for several minutes slightly removing the dried surface rubber.
The rubber compound doesn't really like alcohol (it tends to work briefly then get even worse) or most other solvents.
If you have a copier repair shop nearby, you might try begging a little rubber restorer from them since this problem is common to some copiers too.
The treatment will remove some rubber but leaves a tacky residue that is pretty durable.
When the printhead drive belt fails, replace the printer as the belts run close to $60 US from an aftermarket supplier; HP discontinued them about a decade ago.
Jun 17, 2008 | HP DeskJet 697c InkJet Printer
Lexmark X5250 All-In-One InkJet Printer Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
