Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a cabrio washer top loader HE... it goes threw the wash cycle fine but then it won't drain and if you empty it out the drum is stuck down please any help
    Problem Solver:
  • 9 Answers
If you can hear your pump engaging then there is a clog going either to or from the pump. Often loose change will cover the drain hole in your tub and get stuck there. There are several videos on YouTube that can walk you through the process of removing your tub, and it only requires a ratchet and a little patience. It will be a bit difficult the first time, but after that it is a piece of cake!
Posted on Oct 18, 2013
  • jaretheil
    jaretheil Oct 18, 2013
    A temporary fix that often gets you up and running is to take a vacuum and change the hoses so it blows air out instead of sucking it in. Then take your drain line that dumps the water into the drain in the wall of your house and shoot the air into it. This will often dislodge the foreign matter stuck in the drain long enough to finish a couple of loads. That being said, you will still need to remove either the tub or the drain pump to finish the repair eventually.
SearsTechToo
  • 261 Answers
SOURCE: won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Posted on Nov 01, 2008
  • 125 Answers
SOURCE: Cabrio he toploader leaking on towel/sheet cycle only
It is possible that the dispenser is leaking. It is typically the left front dispenser, you may notice a puddle on the left side. ???
Posted on Jan 09, 2008
SOURCE: AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Posted on Jul 05, 2008
venexcsd
  • 1185 Answers
SOURCE: washer won't drain after rinse cycle
If you lay the drain hose down into a bucket does water come out fairly quickly?
If so then it is not a blockage
You may have a coin or other small object in the pump which stops the impeller turning so no pumping action
Only solution is to check if the pump is free to turn either via the filter opening or taking the back panel off (Remove power before doing so ) and turning the pump by hand (there will be a fan blade on the end which is connected directly to the impeller.
If that will not turn very easily then you need to take off the hoses and check what is happening with the pump unit
Posted on May 23, 2009
SOURCE: cabrio washer wont drain
I had a very similar problem. The washer did not drain anymore and the agitator did not move or very slowly. What I found after removing the back panel and could see the plastic tub, was that a pillow case was clogging the drain. I had to remove the agitator and was able to pull out the pillow case through the slots of the tub. It seems hard to believ that a pillow case would migrate through the small gap of the agitator and tub and then through the slots into the drain cavity but that is what I found. After that removal, the washer worked fine again. Hope that helps.
Posted on Aug 22, 2009
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
The washer will not drain. It goes through all the cycles, fills with water, washes, but when it gets to any of the spin cycles, it stops. The hose going to the drain is NOT clogged.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 04, 2011 | Whirlpool LSR6232J Top Load Washer
What does the "OL" mean on the cabrio washer? it doesn't seem to be spinning out the water either
my cabrio is having problems too it won't go through a full wash cycle ,when it's time to drain it stop.I cleared the drains and even took the drum out and found some socks,then I started it today and it worked till the drain cycle .I also had it run a diagnostic and stopped on C8. I hate laundermatts
Aug 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Top loader washer isn't running threw all the cycles. Drum stays full of water
Probably needs a timer but without a model number, it is only a guess as it could be a motor coupler if it only drains.
Jan 29, 2010 | Maytag Washing Machines
Leaks when the washergoes into the spin cycle.
Could be crack on underhose or possible drum fault
Sep 30, 2009 | Roper RAS6233KQ Top Load Washer
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Whirpool cabrio won't spin cycle
I just paid $85.00 for a tech to come out and pull some socks out that got stuck between washer drum and outside plastic drum. It took 10 mins. top.
It seems when you pull clothes out of washer small items slip between inner and outer drums. BAD DESIGN.
Jul 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water fills drum (top loader) even when off
Your problem is a jammed water solenoid, If you take the top off the machine it is possible to remove and either strip it down to see if it is dirty or replace it. your washer hose usually connects directly to it.
Apr 11, 2009 | LG Washing Machines
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
