Question about Bose Lifestyle 12 System
I have a bose 12 system and the remote only works 4 feet away ! I have tried looking at the antena in the handset re internet threads and have even resolderd the copper antena connections to make sure .. still does not work until close up. I have not moved the base untit or introduced anything that would cause issues.. any one know where or what the reciever is on the base system.. could it be this ??
SOURCE: Bose 321 Remote not working
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
Posted on Jul 04, 2008
sapperj
  • 70 Answers
SOURCE: Turning Off Irregularily
A voltage converter is not neccessarily the proper piece of equipment to use as most equpment comes with a 120/230 voltage selector. What is probably causing your problem is power frquency. Power in India runs on 50HZ, not the 60Hz we use in the states. This causes a slightly longer peak wave and can cause over heating, therefore shutdown. Check to see if the unit has a 50/60 switch and switch to accordingly.
Back when I was a professional sound engineer and toured abroad, we used a device called an auto-former. These changed the frequency and voltage as needed. Unfortunately the first time I went to England I forgot about this, could not find any pre-built ones and had to spend nearly a week designing and fabricating 8 of them....
Posted on Jan 01, 2008
SOURCE: Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Posted on Feb 05, 2008
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Posted on Feb 05, 2009
SOURCE: The remote for Bose lifestyle V20 system does not
I had the same problem, and called Bose tech support. They put me on track to the solution. The code you need is under AUX, Music Player, Apple where you probably looked already. The secret is that you need to "unpair" the apple remote first. If I remeber right, in apple TV you go to settings, general, remotes and unpair your remote. It still works, but is no longer the only remote that works.
Gerry
Posted on Jul 23, 2009
Can you turn it on without the remote? My dog got a hold of the remote and I need to turn it on so I can try to program it to our cable remote.
Learn To Bose Solo TV Sound System 44902 - YouTube
? 2:12
https://www.youtube.com/watch?v=QQziZ3w6z0A
Jun 22, 2015 - Uploaded by Lisa Tiffany Knowles
Learn To Bose Solo TV Sound System Review Read More reviews from Amazon Buyer: ... I received this sound system withno knowledge of what it really is. ... The rep that I worked with (they assign you one person to talk to--a real. live person who emails you ... bose solo tv sound system universal remote
Solo 15 II TV sound system - Bose product support
worldwide.bose.com/.../en_us/web/solo.../page.html
Bose CorporationThe Solo 15 and Solo 10 series II systems dramatically improve television sound. ...Follow these steps to program your BoseĀ® universal remote to control the other ... high quality home theater sound from your Bose system, you should turn off
Jan 05, 2016 | Bose Solo TV sound system - Black
Dropped Bose model rc48s227 remote will not work
Dropped.antena loose open it solder the copper that wrapped around the little black piece of carbon
Feb 11, 2014 | Bose New Original RC48S227 Remote Control
Acer 5760 low volume
Some program have poor sound quality. Laptops are not known for great sound, the speakers are small by design. I use a Bose SoundDock external speaker system. Take a look : http://www.bose.com/controller?url=/shop_online/digital_music_systems/sounddock_systems/sounddock/index.jsp
Jan 12, 2013 | Acer TravelMate 5760 156 320GB 4G...
Rc-9 remote only works if within 2 feet of bose lifestyle 12
Replace its infrared emission LED. It is weak, and so the signal out from the remote control too.
Nov 18, 2012 | Bose RC-18S Remote Control
My bose remote for my lifestyle48 only works from really close up? I was lead to believe they work from any room in the house... what's wrong?
The Bose Lifestyle 48 remote is RF device and is rated to work up to 65 feet (20m) away from the system (brick, steel, etc. construction will reduce this distance significantly however). The remote is discussed in two places of the installation manual.
The first speaks to the receiving antenna on page 16 in the form of a "Note" below section 4G. It states that both of the power cords (one between the VS2 and Media Center the second that supplies power to the VS2) need to be fully extended. Wrapping up excess cable will reduce the receiving range of the system to the remote transmitter.
The second location is at the bottom of page 29. Here, it offers the solution to poor remote performance to be an optional "remote extender" that looks like it connects to the rear of the system (RC connector?). The extender is available for an additional cost and you must contact Bose to obtain it. I can't find an image of it and Bose doesn't produce any information about it when searching their website.
I hope this helps and good luck! Please rat emy reply - thanks.
Apr 21, 2011 | Bose RC-48S Remote
I have a lifestyle 28 and for some time now the range within the remote can be used has reduced a lot, as a matter of fact, sometimes even as short as 4 meters away. I also have noticed that for some...
try t use a remote extender with multiple sensor wich can be use to extend the range of your remote or try chage the battery of your remote....
Sep 30, 2010 | Bose Lifestyle 28 System
37PFL5522D/12 remote channel
hi my name is mark, if i understand you correctly you are using the bose remote to control the tv.if so follow link. http://www.managemyhome.com/mmh/products/ManualSearch.action you will be able to down load the owners manual for your bose system. hope this helps. thanks for your question.
Mar 18, 2009 | Televison & Video
Can i use existing satelite antena on my audi
The antenna should plug into the Stilleto car kit if your Audi is equipped with Sirius already. Otherwise you will have to use another Sirius antenna.
Mar 07, 2009 | Sirius Satellite Radio Receiver
Bose Lifestyle 12 System Logo
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
