Question about LG Computers & Internet
When 'MUTE' button is pressed, 'Fan2 ERROR' appears on the screen. One of the 2 fans in the back of the TV is not working. I removed the back and switched the fans. Both fans work on Fan1 terminal, but both connections meter about the same so I think the problem is software related. I contacted Vizio and they were no help at all. I should mention that i had replaced the YSUS board that had FLS 2 shorted to ground. Any ideas would be appreciated thanks.
2 Suggested Answers
bugoy31
  • 1238 Answers
SOURCE: 'how to replace fan in vizio plasma tv'
just open the cover and unscrew the fan..then you can freely replace it..
Posted on Jun 21, 2012
Testimonial: "Thank you."
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
Jun 21, 2012 | Televison & Video
Its a WD-52631 Rear projection TV. I have sound but no picture. The lamp is still good the problem is somewhere in projecting the picture onto the screen. I have done all the resets i can do and sometimes...
Hi Mark,
First of all thank you for posting your question here at Fixya.
You've mentioned that you can hear a slight grinding noise. This noise came from either a faulty color wheel or fans. To isolate where the fault came from, first I would advice you to access the "error code operational check". This is a built-in software that log and give an equivalent error code by means of blinking LED to determine the exact caused of the symptoms.
How to access the "Error Code Operational Check".
1. Turn on the TV and wait until it automatically shutsdown.
2. Pressing the front panel "Input" and "Menu" buttons at the same time, and holding for 5 seconds, activates the Error Code Mode. The Timer LED flashses denoting a two digit Error Code.Example, if the error code is "42" the led will flash 4 times pause and flash 2 times and it will cycle for a total of 5 times.
Please let me know what is the error code.
If you can't access the error code mode because the TV didn't gone to shutdown. I would advice you to open the rear panel of the TV to pinpoint where the grinding noise came from.
1. Remove 8 screws (A) from the external input frame.
2. Remove 10 screws (B) form the rear cover.
3. Pull the rear cover from the TV.
Tape the lamp cover switch to closed position like on the picture above or else the unit will not turn on.
Your TV has a 3 fans :
1. DMD fan
2. Lamp fan
3. chassis fan
If the grinding noise came from the fan(s) you have to replaced it. All fans have the same part no. 299P312010
However if the noise came from the optical engine assembly, you have to replaced it part no.938P059050
Jdvillanueva
Dec 19, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I HAVE A HL72A650 DLP TV. AT FIRST THE TV STARTED TURNING OFF AND ON . I LOOKED ON THE WEB AND WE HAVE TRIED CHANGING THE LAMP AND THE BALLAST. THE TV IS SILL TURNING ON AND OFF. THE SCREEN DID COME ON...
Sir reset the lamp hour meter if you replace the lamp. Aim the samsung remote at the front panel where the infrared sensor is located, press the following keys on the remote in this order, Mute, 1,8,2,Power. Wait until the your tv screen lights up with the words "loading factory" on it. Press the "down" direction pad on the remote to select "option" from the list of choice that appears on the screen. Press the "enter" button on the remote, select "reset lamp timer " from the list of choices presented on the screen. Press the "enter" button on the remote. Turn off the TV with the remotes power button. Then wait at least five minutes before turning ON again your tv hope this helps good day and best regards.
Sep 23, 2011 | Samsung HL72A650 Television
On screen message "lamp life over, error!!, which
Hello John:
If you replace the DLP lamp out of your Zenith or LG, you will need to reset the counter...otherwise you may get an annoying reminder every few days if you're surpassed the predetermined hour mark.
To Reset:
Ensure the TV is powered on.
1) Press and HOLD the MENU button on the TV
2) Press and HOLD the MENU button on your REMOTE
(hold both these until the service menu pops up 5-10 secs max.)
3) Let go of the REMOTE button first, then release the button on the TV
4) Press and HOLD the ENTER (or OK) button on the TV
5) Press and HOLD the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
6) Let go of the REMOTE button first, then release the button on the TV
We suggest writing your lamp hours on a piece of masking tape and taping it to the back the TV for future reference.
7) To reset the lamp counter, press SELECT (or the button in the middle of the direction arrow buttons). Hit SELECT a second time to confirm clearing the lamp counter
For certain models, you might have to tweak these steps slightly...
Mar 22, 2011 | LG Televison & Video
Toshiba 57H82 convergence problems. TouchFocus
See my solution <http://www.fixya.com/support/t2795690-convergence_off_blue_line_only_vertical>.
You need to get to the service menu--it's been 4 years so go to AVSforum.com to turn off the different guns and get the better pattern.
At your risk: To get into Service mode:
1. Turn your TV on. 2. For X81 or earlier series: Press MUTE on your remote and release. 2. For H80/H81/HX81 series: Press MUTE on your remote and release two times ("Mute" on-screen) 3. Press down MUTE on your remote again and hold. While holding, press the MENU button on your TV set's front panel. 4. Release both buttons. 5. An "S" should appear on your screen. Press MENU again on your TV. 6. Now you're in service mode. Channel Up/Dn - Scrolls through Parameters and Volume Up/Dn - Changes Parameter Value
To get into convergence mode:
Get into Service mode, then Hit '7' to bring up the convergence grid. Buttons 100, 0, and ENT control which gun you want to turn off (if you want to align the red to the green without seeing the blue gun and other variations). 2=up, 8=down, 4=left, 6=right, 3=change gun to converge, 5=converge that point. To exit convergence mode you press 7 once and your screen should look like it's imploding then return to normal and then you press 7 to get back into regular service mode.
I have more info found on the board. -Ken
Jul 31, 2009 | Toshiba 57H82 57" Rear Projection...
How do I stop the menu loop?
press mute on the remote once and then press and hold mute and menue at same time.
An S' will appear on screen.
now you are in the service menue
press key number 9 on your remote this will perform a self Diagnostics
if this dosent work
press and hold volum on front of tv set then press 9 onthe remote.
power set off then on
youe should be reset.
Jan 13, 2009 | Toshiba 27D46 27" TV
Toshiba 47" 1080P LCD 47HL167
Replace the convergence IC and check power resistor for leakage, if values are not exact replace them. Once the parts are in place perform the alignment.
Thank you & post back again if you need additional info.
May 07, 2008 | Toshiba REGZA 47HL167 TV
Resetting the parental control password?
try master pass 3308 Childlock The CHlLDLOCK function prevents chiIdren from watching TV. HoId down the F button and then press the MUTE button until the symboI ? ? appears on the screen, and the TV enters the CHlLDLOCK mode. Except for the symboI? ?, the screen becomes blue back and mutes when you press the buton to turn the TV off, then turn the TV on after setting the CHILDLOCK function. To unlock the TV, hoId down the F button and then press the MUTE button again. Note: The CHlLDLOCK can be set or cancelIed only by the remote controI. After setting CHlLDLOCK, secure the remote control in a safe place
Aug 14, 2007 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Computers & Internet Logo
46 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
