Question about Lexmark C Office Equipment & Supplies
C540 printer leaves burn stain on paper - C Lexmark Office Equipment & Supplies
How do i fix toner stain on printout and photocopies? please what might be the cause of the dot stains?
There are several reasons for stains on a Laser printer or photocopier
1. Clean all rollers. Fuser; transfer and pickup.
2. Ensure the toner is clean from outside.
3. Hope the Toner is not refilled and Is not leaking.
4. Clean paper path.
Mar 08, 2016 | Office Equipment & Supplies
I have Westinghouse oven and on the top of this oven stove is also attached.i covered top stove with foil paper to be saved from stain but today I noticed by removing paper that a big burnt mark is there I...
I believe the burn mark is some of the foil paper that got hot. I would try a wet and soapy rag placed on the stain and kept wet for several hours then with a scotch bright carefully see if it will come off. This may take several tries.
Apr 23, 2014 | Westinghouse Kitchen Ranges
Will not feed paper
Unplug the printer and wait half an hour. You want the internals of the printer to cool down, otherwise they might burn you.
Open the top of the printer, and remove the toner cartridge, there will be visual instructions printed on the top of the cartridge on how to remove it. Take care to place this on paper towels, as toner can be shaken loose and will stain anything it lands on.
You should be able to see a paper jam under where the toner cartridge, reach in and remove this jam.
After you've removed the jam, replace the toner cartridge and try printing again.
Mar 06, 2011 | Brother HL 2140 Laser Printer
Big black vertical line on the back of the paper. Have cleaned the nozzle several times as directed by online instructions, but still ink line tehre, you say clean the nozzle with a stick, but you dont say...
Any ink on back of paper is a stain and not a print. So open the cover and look carefully and well into the printer, the path of the paper, and you will most likely see ink stain about the area where the stain occurs and wipe thoroughly with tissue a soft cloth.
Good luck 7 God bless!
Mar 03, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
How do I clean my new electric Jenn-air cooktop with its glass top? Do I need a special cleaner for the glass?
  • Step 1 Wipe up spills as soon as they happen with a clean dry towel. According to the Jenn-Air website, for glass top cooking surfaces, you should do this even if it is hot since it will be harder to clean up later. Be careful not to get burned.
  • Step 2 Use a cooktop cleaner once it is cool. You can also use dishwashing detergent and water or just a baking soda paste (made with water).
  • Step 3 Apply the cleaner to a sponge, cloth or paper towel. For more stubborn stains, you can use a non-abrasive or "scratchless" pad.
  • Step 4 Rub the soiled areas until clean. Rinse well, especially if you used the baking soda paste as that can leave a residue.
  • Step 5 Use a razor blade for burned on and crusty stains that will not come off using the previous methods. Jenn-Air states to hold it at a 30-degree angle to carefully remove the stain.
  • Or you can use this on the link below.
    http://www.amazon.com/Blue-Ribbon-88100-Cooktop-Cleaner/dp/B000HM5INA
    Good Luck and please rate 4 thumbs up for the free answer
    Jun 25, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Stained paper
    Have a tech from Konica Minolta come out to check machine mite need to have a major cleaning, And have the drum, cleaning blade and developer replaced
    Oct 01, 2009 | Minolta Di152 Laser Printer
    All of a sudden my Canon MP830 is printing only very light, unclear very light black lines on the chapter of my dissertation I am trying to print. All the ink tanks are full & I've done 2 deep...
    Doesn't matter if the ink tanks are full. They may also have dry ink on headers. You could try to draw a black rectangle in MS Paintor any other software and try to print it at the best quality. You also could try to remove the black cartridge and see if it leave a ink stain on a absorbant paper (like a napkin). If does not leave a ink stain it means that the ink is dry.
    If this is the case you may try to boil some water. When the water is boiled take it away from the fire and sink the cartridge into the boiled water and keep it there until the water cool down.
    Aug 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Red toner leaking onto "spongy" rollers and down onto the paper trays
    Hi, its sounds like a faulty magenta cartridge. Contact your supplier for a replacement
    May 13, 2008 | Ricoh Aficio CL2000N Laser Printer
    Stainless steel appliances ie. refrig, dishwasher & oven
    a quality s/s cleaner and a clean cloth sould do the trick for most stains, WD-40 also works to remove the stains, works really well, also leaves afilm on the metal to prevent stains from adhering, just dont use paper towells, the tend to leave fibers behind. and also look closely at the s/s there is a GRAIN pattern in the metal just like wood would have a grain!! be sure to wipe in the direction with the grain not against.
    Mar 19, 2008 | Refrigerators
    43 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
