Question about Suspension & Steering for Mazda MAZDA5
Replaced complete control arm with new ball joint but still clunking.. can it be the wrong bolt or wrong hardness of bolt??
    New Friend:
  • 43 Answers
Is the clunking occuring when steering or just on rough roads? With suspension clunks tie rod ends are the most comonly over looked component. To check the tie rod ends jack up each side individually and place jack supports under vehichle in manufacturer allocated position with the parking brake on , on a flat surface . Check the tire deflection by attempting to turn the tire by hand in a side to side fasion also check the lateral deflection of the wheel bearings . There are inner and outer tie rod ends on your vehichle . Other suspension components that can cause clunking are the struts to check these bounce the car as you would a basket ball with your hand by pressing firmly down on each front corner and releasing you may hear the clunk during this test as well.
Posted on Oct 15, 2013
2 Suggested Answers
jerry_kramer
  • 3904 Answers
SOURCE: My 2008 Mazda5 is twisting from side to side when I accelerate, then let off the gas a bit.
Pulling hard seems to me that a bearing may be freezing up/going bad or a brake is not consistently releasing. Is this more noticeable as you break or is there any grinding?
Posted on Nov 13, 2012
Front left ball joint for 06' Mercury Montego
The ball joints are part of the lower control arm . The control arm is not extremely difficult, but not easy either. First remove the nut on balljoint, then pull the ball joint out of the knuckle, that may take a pry bar, remove front control arm nut and bolt, and two bolts on rear of control arm bushing, reverse process to install. The Ford workshop manual says to replace the control arm nuts and bolts, but I hardly ever do. Have never had a problem. Torque front bolt to 111 lb-ft, and rear to 73 lb-ft. Hope that is good for you.
KIP. Martin, service manager Ford dealership.
Mar 25, 2014 | 2006 Mercury Montego
How to change rear ball joints on 2002 dodge stratus
Instructions
  1. Remove the Upper Control Arm
    • 1Disconnect the ground battery cable using a wrench.
    • Loosen the front wheel lugs located on the same side of the upper ball joint you need to replace. Use a lug wrench.
    • Raise that same front wheel off the ground using a floor jack and support the vehicle on a jack stand.
    • Finish removing the tire.
    • Take the cotter pin off the upper ball joint stud holding the steering knuckle arm. Use a pair of nose pliers.
    • Remove the castle nut from the upper ball joint stud using a wrench or ratchet, ratchet extension and deep socket.
    • Loosen the two bolts securing the back of the upper control arm to the mounting bracket. Use a wrench to hold the bolt head as you loosen the retaining nut with a ratchet and socket.
    • Pull the control-arm ball joint off the steering knuckle arm. You may need to use a Pitman arm puller to free the ball joint.
    • Finish removing the two bolts from the back of the upper control arm and lift the upper control arm off the vehicle.
    Install the New Upper Control Arm
    • Set the new upper control arm in place and install the two bolts and retaining nuts to secure the back of the upper control arm to the mounting bracket. Remember the bolt heads should point inward toward the shock absorber with the retaining nuts on the outside of the mounting bracket. Do not tighten the bolts yet.
    • 11Insert the control-arm ball joint on the steering knuckle arm and start the castle nut with your hand over the ball joint stud. Do not tighten the nut yet.
    • Tighten the two bolts on the mounting bracket to 67-foot lbs. (91 Nm) using a torque wrench. Hold the bolts with a backup wrench as you tighten the retaining nuts with the torque wrench.
    • Tighten the ball-joint castle nut to 45-foot lbs. (61 Nm) using the torque wrench, ratchet extension and deep socket.
    • Install a new cotter pin through the joint-ball stud hole using the nose pliers. If necessary, tighten the castle nut just a few degrees to clear the stud hole through one of the castle nut slots.
    • Mount the tire on the wheel assembly and install the wheel lugs using the lug wrench.
    • Lower the vehicle and finish tightening the wheel lugs.
May 31, 2012 | Dodge Stratus Cars & Trucks
How to replace ball joints
the lower ball joint is pressed into the lower control arm. You will need a ball joint press to remove and install the ball joint. The other option is to replace the lower control arm.
Some parts store will have presses for loan. You will have to check around and see if any in your area have these. If you can't find one you could always pull the control arm and bring it to a shop or machine shop and have them swap the ball joint.
Its a pretty simple procedure.
1. remove the wheel
2. remove the pinch bolt that secures the knuckle to the ball joint.
3. separate the lower control arm from the knuckle.
4. remove snap ring from the ball joint (if it has one)
5. use a ball joint press to press out the old ball joint.
6. press in the new ball joint.
if you don't have a press than you can remove the lower control arm by following steps 1-3 above. then remove the bolt from the front bushing. Remove the stamped steel skid pan from the sub frame. Remove the rear lower control arm bushing mounting bolts.
If you have any questions I'll be happy to answer them.
Oct 13, 2011 | 1998 Dodge Caravan
Lower ball joint 2002 hyundi santa fe
Typically these are replaced with a complete lower control arm. What happens is the ball joint is reseeding the lower control arm and rusts. When the old ones pressed out it distorts the opening in the lower control arm. When the new one is pressed in they never fit tight. Anew lower control arm is very easy to replace. 1. Jack up the vehicle on the sub frame or pinch weld. 2. Remove the pinch bolt that holds the ball joint to the knuckle. 3. Separate the ball joint from the knuckle. 4. Remove the two bolts that secure the horizontal bushing to the sub frame. 5. Remove the single bolt that secures the vertical bushing from the subframe. 6. Remove the lower control arm. If you have any questions I'll be happy to answer them.
Sep 25, 2011 | 2002 Hyundai Santa Fe
Ball joint repair and how do you do it
To perform the following procedure, the lower control arm must be removed from the vehicle. Refer to Removal And Installation for that procedure.
  1. Using a screw driver or other suitable tool, pry the seal boot off of the ball joint assembly
  2. Position receiving cup, Special Tool 6758 to support lower control arm when removing ball joint assembly. Install Remover, Special Tool 6919 on the top of the ball joint assembly.
  3. Using the arbor press, press the ball joint assembly completely out of the lower control arm.
NOTE: When installing ball joint in lower control arm, position the ball joint in control arm so notch in ball joint stud is in the direction shown. This will ease assembly of the ball joint to the steering when installing pinch bolt.
  1. By hand, position ball joint into ball joint bore of lower control arm. Be sure ball joint is not cocked in the bore of the control arm, this will cause the ball joint to bind when being pressed into control arm.
  1. Position control arm with installed ball joint, in an arbor press with Receiving Cup, Special Tool 6758 supporting the lower control arm. Then center Installer, Special Tool 6908-4 on the bottom of the ball joint
  2. Carefully align all pieces. Then press the ball joint into the lower control arm until it is completely seated against surface of lower control arm. The ball joint is correctly installed when there is no gap between the ball joint and the lower control arm. Do not apply excessive force against the ball joint or the lower control arm.
  3. Install a NEW seal boot by hand as far as possible on the ball joint. Installation of the seal boot is to be with the shield positioned as shown.
CAUTION: Do not use an arbor press to install the sealing boot on the ball joint. Damage to the sealing boot will occur if excessive pressure is applied to the sealing boot when it is being installed.
  1. Place Installer, Special Tool 6758 over seal boot and squarely align it with bottom edge of seal boot. Apply hand pressure to Special Tool 6758 until seal boot is pressed squarely against top surface of lower control arm.
CAUTION: A replacement ball joint is not pre-lubricated. Properly lubricate the replacement ball joint using Mopar Multi-Mile grease or an equivalent. Lubricate ball joint after seal boot is installed but prior to top of seal boot being pushed down below notch in ball joint stud. Air must vent out of the seal boot at notch when grease is pumped into ball joint, failure to do so will balloon and damage seal boot. Do not over grease the ball joint, this will prevent the seal boot from pushing down on the stud of the ball joint.
CAUTION: After the ball joint is properly greased, clip the end of the grease fleeing off below the hex. The ball joint seal boot is non-purgeable and further greasing is not required and can result in damage to the seal boot.
  1. Reinstall lower control arm on vehicle.
Mar 07, 2011 | 2000 Dodge Caravan
How to replace lower ball joint on bmw e46
I understand that there is a tool designed to press out the outboard ball joint. I have never heard of anyone using one.
You can press out the ball joint using a hydraulic press. Actually you would need to do both ball joints because you will trash the inboard ball joint getting the control arm off to take it over to your press. Neither the dealers nor the independent shops do that either.
Your front suspension has very little adjustment, and those aluminum control arms get bent. You would cry if you went through all the effort of replacing the individual ball joints and then realized that the control arm was bent.
So far as I know, Dealers, shops, and DIYers all buy complete control arm assemblies and bolt them on. Be prepared to hit your pickle fork with a big hammer to separate those ball joints from the car.
You will almost certainly need fresh control arm bushings if you replace the arm, and you probably need them even if you are using the old arm.
Feb 19, 2011 | BMW X3 Series Cars & Trucks
How do you replace ball joints
Removing the Ball Joint Step 1 Loosen the lug nuts on the front wheel assembly with the ball joint you need to replace. Do not remove the lug nuts.
Step 2 Set the transmission in neutral (manual) or park (automatic) and raise the wheel off the ground using a floor jack. Then support the car on a jack stand.
Step 3 Chock the rear wheels and apply the parking brake.
Step 4 Remove the wheel lugs and the wheel assembly.
Step 5 Remove the mounting nut and dished washer that secure the stabilizer bar to the control arm. Use a wrench or ratchet and socket.
Step 6 Unscrew and remove the mounting bolt and nut holding the inner side of the control arm to the car's body. This will relieve the tension on the stabilizer bar. Use a wrench to hold the mounting bolt as you unscrew the nut with a wrench or ratchet and socket.
Step 7 Unscrew the bolt on the steering knuckle that holds the control-arm ball joint to the knuckle. Use a wrench or ratchet and socket.
Step 8 Spread the steering knuckle joint that holds the control-arm ball joint to the knuckle. Use a large screwdriver or pry bar. Then separate the ball joint from the steering knuckle.
Step 9 Pull the control arm from the stabilizer bar.
Step 10 Remove the stabilizer bar spacer from the control arm and keep it in a secure place. You will need to use it on the new control-arm ball joint assembly.
Installing the Ball Joint Step 1 Insert the new control-arm ball joint stud into the steering knuckle joint. As you look through the mounting bolt hole on the steering knuckle, align the notch on the ball joint stud with the hole. Insert a new ball joint mounting bolt and start a new nut on the bolt. Tighten the nut.
Step 2 Mount the stabilizer bar spacer in the control arm, then insert the stud bolt at the end of the stabilizer bar into the control arm mounting hole and spacer.
Step 3 Set the other end of the control arm in its mounting position and insert the mounting bolt. Then start the mounting nut on the bolt by hand.
Step 4 Hold the head of the mounting bolt that secures the control arm to the car's body using a wrench, then tighten the nut.
Step 5 Secure the stabilizer bar to the control arm with the dished washer and mounting nut. Tighten the nut.
Step 6 Install the wheel assembly and lugs. Tighten the lugs with the lug wrench just enough to hold the wheel assembly firmly in place.
Step 7 Lower the vehicle and finish tightening the wheel lugs.
Step 8
Remove the chocks from the rear wheels.
Aug 08, 2010 | 1998 Ford Escort
I need to replace upper right ball joint, 98 honda civic
This is a pretty easy job.The way i do it is take the two 14mm bolts louse from the strut on the inner fender well,then take the 17mm bolt out of the bottom of the strut on the lower control arm this will make it drop down.Then take the 14mm bolt louse that fastens the ball joint to the spindle take a hammer and hit the upper spindle and it all will come apart.Now you will have the two bolts that holds the upper control arm in place these are 17mm bolts drop the strut down and remove the upper control arm now you can go in with the new one.Hope this helps !!!
Mar 19, 2009 | 1998 Honda Civic
Replace ball joints
Remove in this order: wheel, loosen the 4 lower ball joint set bolts, cotter pin and nut from tie rod, tie rod from ball joint bracket, ball joint from lower control arm, 4 lower ball joint set bolts, ball joint from suspension. Install is reverse but don't tighten the 4 lower ball joint set bolts.
torque is as follows:
ball joint to control arm- 112 ft-lbs
Tie rod nut- 67 ft-lbs
lower ball joint set bolts- 83 ft-lbs
remember to use a new cotter pin
Oct 08, 2008 | 2004 Toyota Tacoma
I want to replace lower ball joint on my nissan altima 2001
Remove the castle nut on top of the ball joint that secures the ball joint to the spindle. separate ball joint/lower control arm from spindle.Remove lower control arm bolt attatching control arm to subframe/engine cradle. Remove control arm. Replacement is recersal of the removal. Nissan/Infinity ball joints can not be pressed out or in. They are replaced with the whole new lower control arm as one (On most Nissan/ Infinity vehicles, although some exeptions apply. Hope this helps.
Daniel G.
Oct 06, 2008 | 2001 Nissan Altima
Suspension & Steering for Mazda MAZDA5 Logo
93 people viewed this question
Top Mazda Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
David Burbee
David Burbee
JOHN LAPIER
Are you a Mazda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
