Question about ZoneFirst MSS Damper Actuator
Zonefirst msr actuator not opening/air not blowing through vent
1998 dodge durango heat works fine just barely any air blows out vents Fan seems to run fine and at all speeds
could be the vent door actuator not opening all the way . under the dash there is the blend door actuator and the vent actuator that are controlled by vacuum
Feb 26, 2014 | Cars & Trucks
1995 chevrolet pickup, air only blows from the bottom air vent and not the top vents.
these trucks have 3 actuators. none of these other people have a clue obviously. theres one directly to the right side of the gas pedal. theres another one directly behind the tape player deck. there is a third one behind and just below the glove box. the one behind the tape deck controls between hot and cold air. the one near the gas pedal controls A/C. the one beneath/behind the glove box controls where the air blows. please dont believe these people. there is a video on youtube that shows the location of all the actuators and shows the actuators while installed in their place.
Aug 16, 2012 | 1995 Chevrolet K1500
Drivers side vents are blowing warm air when in the A/C mode. Passengers side vents blow cold air.
There are actuators that open the vents...im betting that side's are stuck.
Aug 19, 2011 | 2003 Toyota 4Runner
2005 jeep grand cherokee ac blows cold only out drivers vent. rest of vents are just blowing air. freon is full. no dual air or auto temp.
THE ELECTRIC ACTUATOR MOTOR NOT WORKING. NOT ALLOWING AIR DOOR TO OPEN SO THE AC AIR CAN CIRCULATE THROUGH THE VENTS.
May 24, 2011 | 2005 Jeep Grand Cherokee
Driver side air on the duel climate control is blowing hot and the rest of the vents are cold
Joey i had a similar problem in my 2000...The problem lies in the A/C Actuator. The Actuator is what opens and closes the vents, when the vents are open it allows hot air to flow through and when thier closed it prevents hot air coming in while air conditioner is running. depending on the year some vehicles require an upper and lower actuator. they are fairly simple to replace, and dont take much time. most actuators are located under the control switch box (radio, a/c dials) parts run about 60.00 each.
Sep 11, 2010 | 2002 GMC Sierra C/K1500
The driver side vents are blowing hot air as if the heater is on but the thermostat is set on 65 and the passenger side is blowing cold air as it does normally.
Its called "AC Vent Door Actuator" when this fail they will stay open or Closed, this will happen on vehicles that have Dual Climate control. You can Google it just type Year, make ,model and AC vent door actuator after that. It will definetly have to be replaced. Good Luck.
Sep 06, 2010 | Chevrolet Silverado Cars & Trucks
There's warm air blowing out of the driver-side
Most of the time the dash has to come out to access the actuators on the heater box.
Jul 14, 2009 | 2006 Subaru B9 Tribeca
2004 Ford Expedition XLT, front blend door actuator
Hope I was avle to help, glad you up and going.
May 26, 2009 | 2004 Ford Expedition
ZoneFirst MSS Damper Actuator Logo
42 people viewed this question
Top ZoneFirst Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a ZoneFirst Heating and Cooling Expert? Answer questions, earn points and help others
