Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Orange light not working
  • Official Brand Answer
  • 4,342 Answers
Good Morning Raj, thank you for your post!
Are you referring to the orange light on the freezer is not working or the freezer itself is not running? May I have the model number? The serial tag, which lists your model number, is typically located inside the cabinet, on the left side wall. With this information I can better address the issue at hand.
Posted on Oct 15, 2013
What is the orange light for on unidentified freezer?
If that orange light is on the front of the freezer, on the top or bottom, it is very likely a light telling you the freezer is not cold enough inside, and the food is in danger of spoiling.
It may also be a "on" light.
If you will find a freezer thermometer and put it inside, you can tell whether it is an "on" light or a warning light.
Usually freezers run temperatures of about 10 degrees Fahrenheit or lower if they are working correctly.
God bless your efforts.
Feb 11, 2016 | Freezers
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
The standby light is still on
Are you sure it is a standby light? Usually the orange light is showing you it is in fast freeze. Try switching the orange button off and monitor the temperature. The freezer should cycle on and off, not run continuously.
Apr 15, 2012 | Whirlpool 10 cu. ft. / 283 liter Chest...
Orange light is on instead of green in the freezer does this mean anything?
no. the orange light is the temperature light and the green light is the mains light.
Apr 06, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
We got a philips whirlpool chest freezer my husband pressed orange button as he was told it was turbo boost freezers only cold at bottom and red light is on
Orange switch only by passes the thermostat. It sounds like your freezer is either out of gas or the cooling fan (if there is one) is not working.
Dec 08, 2009 | Whirlpool Freezers
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
The orange light has gone on and I dont know what that means.
orange light is usualy defrost cycle
if fridge not working it is usualy time for a thermostat and a timer moduel
Aug 03, 2009 | Whirlpool Freezers
Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
Jun 24, 2008 | Freezers
Defrost light stays on
Try advancing the defrost timer manually.
Jan 16, 2008 | Freezers
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
93 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
