Question about Vizio Vht215 Home Theater Sound Bar With Wireless Subwoofer
Subwoofer wont link up - Vizio Vht215 Home Theater Sound Bar With Wireless Subwoofer
Subwoofer does'nt link with sound bar
  1. The wireless link indicator lights red. Or alternates red and green.
    There is no link between this unit and the active subwoofer.
    Check that this unit is turned on.
    Ensure that the digital transmitter is fully inserted
    into the digital transmitter dock on this unit.
    Turn the active subwoofer off and then back on.
    Alternatively, turn the active subwoofer off, disconnect the AC power supply cord and then reconnect it.
    Consult your dealer if the problem persists.
    Taken from the Panasonic SC-HTB520 Manual
Oct 26, 2012 | Panasonic Audio Players & Recorders
12in rockfordfosgates wont play bass
is it the proper amp it must be class D amp or bridgeable 2 or 4 channel. how do you have it hooked up?
Jun 12, 2012 | Rockford Fosgate RFP3212 Car Subwoofer
I have a Harmon Kardon HK3490 receiver which has an input for a powered subwoofer. Next to the subwoofer output is a "link switch" which turns on the subwoofer when I turn on the stereo. What...
Connect the Subwoofer Trigger Output for each subwoofer to thecorresponding trigger input on its amplifier. This enables the subwoofer toturn on or off together with the HK 3490. To further conserve energy,when the trigger connection is made, turn the Subwoofer Link Switch onto turn the subwoofer off when the corresponding pair of main speakersare not being used, such as during muting, when headphones are beingused, or when the main speakers are turned off using the Speaker 1/2 switch
Apr 05, 2011 | Denon AVR-687
My car is a nissan micra wont start the engine is trying to turn over but wont roar into life it nearly does then cuts out any suggestions to remedy this
You have posted the problem under "Car Speakers & Subwoofers" category.
Kindly submit the question under Nissan cars section on the website by clicking this link so that the best car experts can view and post a solution to the problem.
On the page which opens, type the question in the "Ask an Expert" box on the right hand side of the page and click on "Post a problem" button.
Thanks for using FixYa.
Feb 22, 2011 | Car Audio & Video
In the Lanzar HRB212 bandpass enclosure.. are the 2 subwoofers wired/connected in parallel or two independent connections? What is the individual rating/specs of each subwoofers?
I looked at a couple of sites and one site said two 4 ohm subwoofers.That means they have to be parallel.It didn't say about the connections.Here is a link that better describes them.They are loud.I SAID HERE IS A LINK THAT BETTER DESCRIBES THEM.LOL Good luck and rock on! Greg
http://www.onlinecarstereo.com/CarAudio/p_16424_Lanzar_HRB212.aspx
Aug 19, 2010 | Lanzar HRB212 Car Subwoofer
Its blown, wondering if there is a way to repair it.
call kenwood customer support and find out if they or someone else makes a recone kit for it. If its one of there top of the line subwoofers they probably will. If its just one of their entry line subwoofers im willing to bet that they wont.
Aug 07, 2010 | Kenwood eXcelon KFC-XW1000F Car Subwoofer
Cant seem to find fuses that wont blow for my 10' re series speakers
if a fuse does not blow when a short is present then the wire or unit will catch fire. You have a dead short most likley in the subwoofer. If you unplug the subwoofer and the fuse does not blow then your unit failed.
May 27, 2010 | Cerwin Vega LW10 Subwoofer
My dual subs wont light up and my ndual tweeters wont either
check the wire connection with the lights then bulbs okay then look on the inside of the box for an extra wire for power for the lights if that dosent work
Feb 02, 2009 | Dual XNBP12D Car Subwoofer
Vizio Vht215 Home Theater Sound Bar With Wireless Subwoofer Logo
Top Vizio Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
