Compressor may be bad - do you hear motor running??? It may need freon. Airflow may be blocked -- keep area clear just like intake vents on floor, must be kept clear to allow proper air flow.
Check the ice bank door to make sure it is closed properly. It is the door that covers the icemaker. Usually that is the problem that someone has left the door ajar leaking freezing temperature into the refrigerator.
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
