Question about Maytag Centennial Top Load Washer
I have a Maytag Centennial Washer (2009) on which I replaced the solenoid part three months ago. At that time the pipes in the house would knock when the washer was filling with water. Now the washer will not fill with water at all. I have checked the hoses and strainers, and these are fine. The washer will agitate and spin, just no water. Should the solenoid be replaced again, or could there be another problem keeping the water from entering the washer?
    Top Expert:
  • Maytag Master
  • 23,227 Answers
I would check the solenoid is working and from that it will be obvious where the issue lies.
Posted on Jun 15, 2017
docjohn174
  • 943 Answers
SOURCE: May tag washer will not agitate, spin water out
hi i would check the water level control
Posted on Sep 26, 2008
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
TheMobilian
  • 8220 Answers
SOURCE: centennial washer, will fill with water, wont spin
Easy fix. Lid switch is bad. This is a direct drive machine. Older models would wash but not spin these latest babys won't wash or spin with the lid switch broken. To access te switch you flip up the control by using a putty knife to release each end. Older models had a screw that needed to be removed, not so with the newest ones. The switch has 2 hot wires and a ground wire. Jump them 2 hot wires and see if she runs
Video: How to get into these machine:
How it works
Posted on Apr 30, 2011
e-Guru
  • 3917 Answers
SOURCE: 18 months old, Maytag Centennial
Hi
May be a plugged Pressure Hose connected to the Water Level Switch in the Control Panel,
other end connects to Tub. Try blowing through the Pressure Tube .
This problem is going to be in the water level control or the tube that connects to the control may be partially clogged. if it is partially clogged the tube can retain pressure essentially fooling the water level control into thinking the tub is full. The best thing to do is to take the washer apart and check the tube to see if it is clogged and if not replace the water level control.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 03, 2011
americangenn
SOURCE: Maytag washer will not fill with water. It does agitate and spin
My May Tag model LA 882 washing machine is not draining water. the water remains even after spining and the cycles are longer durations. any advise ?
Posted on May 26, 2012
Specs for model#MVWC400XW0 Maytag Centennial Washer
It definitely could be a clogged or bad pump. However, it's always a good idea to check for error codes before replacing a part...Especially expensive ones...
http://applianceassistant.com/Washer-Repair/Maytag-Centennial/Maytag-Centennial-Washer-Error-Fault-Codes.php
Hope it helps! Good luck!
Mar 02, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Repair manual Where I can download the repair manual for the maytag centennial washer
This is a manual. Since there are so many versions, you might need to search for the appropriate one. I searched for "Maytag centennial top load washer repair manual". There was a Maytag site, but download was very slow. http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf#zoom=100#scrollbar=1#toolbar=1 http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf
Jul 30, 2014 | Maytag Centennial Top Load Washer
Maytag Centennial Top Load Washer drains as it fills.
The water is probably siphoning out of the tub. Your drain pipe is either too low or the drain hose is down too far into the pipe. Take the drain hose out of the pipe and lift it high. I'll bet your problem goes away
Feb 06, 2014 | Maytag Centennial Top Load Washer
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
I Bought a Bravo series 300 Washer and Dryer 18 months ago. They came with a 1 yr. manufacture warranty The first month I had problems with the dryer which was covered under warranty.. It was inconvenient...
hi,
usually most areas have a USED appliance store. usually these guys will have a bunch of old fridges and stoves around outside the store. Our town has three or four of them. you may have to ask around but these guys usually have parts for cheap. and they will sometimes make house calls. try googling used appliances in your area. they may also set you up with a cheaper washer with a METAL tub.
good luck
jm
Nov 15, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Pipe banging
Sounds like a solenoid problem in the washing machine
Jan 25, 2010 | Maytag Centennial MVWC500V Washer
Washer is 8 months old. Three bad pumps
I would call Maytag directly and ask them to replace this washer for you or have them provide FREE to you, at least a lifetime warranty on the pump and a five year warranty on the rest of the washer parts. Sounds like you got a lemon unless you wash lots of rugs or have a hair salon. If this is the case, you won't be able to get a new warranty, but if it is NOT the case, I'd take this all the way to the head of Maytag and they should make this right for you. I hope this turns out well for you, I'd like to know the outcome. The best of luck to you!
Sep 07, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Centennial Top Load Washer Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
