No signal checked ariel this is ok - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 35,601 Answers
You may have to repeat the initial setup procedure and search for active channels in your area
Posted on Oct 14, 2013
2 Suggested Answers
  • 12 Answers
SOURCE: my mother in law has a 3 mth old panasonic tv with built in freeview that keeps going off saying no signal check ariel. ariel has been checked, any ideas anyone please
access the signal strength in the menus and see how it looks. Too strong a signal can also produce the same problems as a weak signal. If it shows full strength but poor quality then it may be too strong a signal.
Posted on Mar 23, 2013
THIS PROBLEM IS NOT LOGICAL-SIGNAL STRENGHTS HAVE BEEN CHECKED AND WAS OK BUT THE PICTUE KEEPS BREAKING DIFFERENT ON 3 DIFERENT TVS IN THE HOUSE BUT WHEN I REMOVE ANY ONE OF THEM AND CONNECR IT INTO O
In fringe areas; where signal strength is too weak, this should happen. It sounds that, you're using an Ariel booster along with a splitter. Just connect one TV at a time, without using the splitter. If picture break occurs even this time, adjust the the signal strength of the booster [either low or high], and check whether it can help you. Keep in mind, iv the signal strength is too low, or set to too high, this fault will happen, as AGC [automatic Gain Control] circuit inside the set won't function properly. Gopakumar Gopalan Google
Dec 15, 2014 | Toshiba Televison & Video
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
Tv has no signal
The TV you are trying to connect to may be an older type and not a DIGITAL receiver. The old ANALOG type no longer work with the Digital applications unless to have a CONVERTER BOX.
Dec 22, 2013 | Televison & Video
Getting all snow with a "no signal" message power is good to box
Check its ariel connection for firmness. If it is OK, check and replace its tuner.
Apr 24, 2013 | Sony KDS-60A2000 60" HDTV
My mother in law has a 3 mth old panasonic tv with built in freeview that keeps going off saying no signal check ariel. ariel has been checked, any ideas anyone please
Mar 23, 2013 | Televison & Video
I was given a technika hd ready dvbt dvd built in freeview with no instructions.I need instructions how to tune in freeview.It had previously had the freeview tuned in but now the channels are not...
hi,
First of you have to check the Atenna connection in the rare of your tv. Check for any loose contact on the connection of the wire to the pin. may be its the cause for showing signal as 0%. you can confirm the same by connecting the tv at the place where you doughters tv is connected. If there you get the picture then there is some thing wrong with the atenna connection.
If want information how to tune your tv then need information like BRAND and MODEL NUMBER of you TV.
ok
Aug 05, 2011 | Televison & Video
Sony V lcd 32 inch losing digital channels and after doing a resetting scan it is ok for about 30 mins.... then screen image breaks up totally and message 'weak signal' shows on screen. Help,please.
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at www.digitaluk.co.uk
Thanks
Nov 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No signal coming through
Only way really is to disconnect your ariel and connect it to another ariel.
Sep 22, 2009 | Televison & Video
Can't Receiver ( No Signal )
I WOULD SUGGEST THE ARIEL BREAKING DOWN, OR AN INGRESS OF WATER IN THE COAX CABLE. IF YOU NO SOMEONE WITH THE SAME UNIT TRY YOUR UNIT ON THERE ARIEL.
Feb 27, 2008 | Furuno GP32 GPS Receiver
LE32R74BDX
this is because most new lcd tv's have a poor tuner built in and require a stronger ariel, to pull in the analogue or digital signal. Check that your ariel is freeview capable whether using freview or not, as these ariels are better at pulling in the signal, or do what i have had to do and buy a mains plug in signal booster from Asda for about £6.00, this did the trick, especially if you don't want to replace an ariel costing about £30.00
Jun 13, 2007 | Samsung LN-R409D 40 in. LCD Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
