Question about Refrigerators
Whirlpool wbm482 1X fridge freezer(853477465030), fan and light comes on and its pluses(on off, on off) when door is open. What could the problem be?
    Top Expert:
  • Refrigerators Master
  • 36,394 Answers
The switch could be dirty or defective
Posted on Oct 14, 2013
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
  • 82 Answers
SOURCE: whirlpool fridge freezer ARC 4030?
Look to have the control module repaired / replaced.
Hope this helps
Posted on Dec 03, 2009
My whirlpool fridge is getting warmer
there is a dampener control that lets air over to ref section, put your hand at the area to see if air is coming over from freezer.
if not look in freezer in back to see if it is all frozen, if so call tech.
if not push light button in freezer side with door open and liston for fan if fan does not run that is your problem.
May 03, 2014 | Whirlpool Refrigerators
Whirlpool WBM39MW alarm when door opened
Just had one of these with the blinking light, fan pulsating and no cooling. The fault is the power supply section in the control module at the back. It is a 2uF 400VAC capacitor going open circuit. make sure you replace this capacitor with something equal or better rated - it is critical
Jun 17, 2012 | Whirlpool Refrigerators
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
Whirlpool fridge freezer ARC 4030?
Hope this helps
Dec 02, 2009 | Whirlpool ARC4030 Stainless Steel Top...
I have a whirlpool upright fridge freezer. I want
Switch to fridge off. If you have a household fan, or pedestal fan, you can open the door, remove all the drawers and food, place the fan pointing toward the cabinet. It will defrost in minutes without damaging anything. Just remember that there will be water so you need to mop it up or put a thin container near the front where it runs out. Do not use any sharp object to loosen ice, you can puncture the refrigerant tubing.
Nov 18, 2009 | Cars & Trucks
Fridge light comes on & sound but not cold
The freezer fan motor may be bad. The main back panel in the freezer can be removed to check it out. Spin the motor wiht your finger to see if it tries to run. If it does then it is shot.
Go here for:
Whirlpool Refrigerator Parts
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Apr 01, 2009 | Whirlpool ED5VHGXM Side by Side...
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
New refridgerator delivered this morning to replace the same model that was a lemon. The fridge is making a sound on the fridge side. When I open the door to the freezer side the sound stops. When I...
sounds as if there is an issue with the evaporater fan motor, perhaps the fan blade has come dislodged and is makinf noises, normal for the fan to stop when the frig door opened as welll,
Dec 17, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
