Question about Plantronics Voyager Legend
My phone turns off when I have my plantronics voyager legend turned on. When I get a call, the phone shuts off before I can answer it.
5 Suggested Answers
wb91
  • 126 Answers
SOURCE: plantronics voyager 835..when I go out of range of
Try re-pairing your bluetooth to your phone. You first have to delete it then start over, if you have your manual use it, otherwise here is a copy.
http://www.plantronics.com/us/media/media-resources/literature/user_guides/voyager835_ug_en.pdf?WT.dl=20
Good luck from Headsets Direct - 800-914-7996.
Posted on Aug 19, 2011
HDI Headsets
  • 537 Answers
SOURCE: my plantronics voyager pro will not charge turn on
I have seen on some Plantronics Bluetooth headsets that you can perform a system reset by doing the following, It might help but not sure.
Instructions:
While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Good luck from Headsets Direct!
Posted on Oct 24, 2011
HDI Headsets
  • 537 Answers
SOURCE: plantronics voyager pro plus is
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Posted on Oct 27, 2011
HDI Headsets
  • 537 Answers
SOURCE: I am trying to connect my Plantronics Voyager 500A
The Plantronics Voyager 510S / 500A base should work just fine with the AT&T phone, here is the link for the user guide below.
Plantronics Voyager 510S/500A User's Guide
Posted on Oct 31, 2011
How do I turn off automatic streaming?
This is a suggestion. Go to settings on your phone, click on Bluetooth, if you're using the Legend at this time, click on legend. You should show two profiles, call audio and media audio, turn off media audio by removing the checkmark in the box. Hope this helps.
Jun 22, 2014 | Plantronics Voyager Legend
When call come in, I say "answer" call goes to handset, not to headset
Here is Plantronics support page: Support Knowledge Base You can also get the user guide of you need one.
Jun 19, 2014 | Plantronics Voyager Legend
How can I reset my voyager legend headset
www.plantronics.com/us/product/voyager-legend
Jun 11, 2014 | Plantronics Voyager Legend
Not asking to answer or reject call
probably you set it to automatic answer,kindly open your settings for call/chat for resetting it.and click for do not prompt before answering
Jan 25, 2014 | Plantronics Voyager Legend Bluetooth...
My Plantronics Voyager Legend has a constant buzzing noise, it does not work at all. When I turn it off or on, it does not matter, just a buzzing noise.
I just had this happen to me. Like yours mine just kept buzzing and the on and off switch had no effect. It just kept buzzing.
The way I was able to fix it was to reset the device by holding both the mute button and the call pick up button until the buzzing stopped. It took only 3 seconds to fix and it immediately began to work. When I switched it on the buzzing was gone and it was working again.
I hope this helps anyone as I didn't see and answer to this issue online anywhere and had to figure it out myself. Take care.
Mar 18, 2013 | Plantronics Voyager Legend
Cannot pair my nokia N6730c with plantronics voyager 520
You want to remember that newer phones are like small computers, so
they may become corrupt over time and you may need to reset them every
so often. Simply turn your phone off and remove again the battery for
a few seconds, then replace the battery and turn it back
on again. Then carefully follow the pairing instructions in the attached link.
Plantronics Voyager 520 User's Guide
May 29, 2011 | Plantronics Hama Voyager 520 Bluetooth...
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
My ear piece keeps losing its pairing
Please remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Purge from the phone any pairing information for your Voyager Pro headset and pair it again with your phone, following the instructions on the link below for the Plantronics Voyager Pro.
Plantronics Voyager Pro User's Guide
Jan 20, 2011 | Plantronics Voyager PRO Bluetooth Headset
I can't answer the phone from my headset and once i'm finished talking I can't disconnect I have to use my phone to answer and disconnect. It was working fine but I'm not sure what happened
It sounds like the wireless link between the phone and headset has been compromised. Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Purge from the phone any pairing information for your Voyager Pro headset and pair it again to your phone, following carefully the instructions on the link below for the Plantronics Voyager Pro.
Jan 05, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a samsung rogue and I all I hear is mostly static with the Plantronics Voyager PRO
Make sure that it has a good connection, try to re-pair the headset to your phone. Before running through the pairing process, be sure to totally delete the headset from the phone's menu. You may want the headset turned off for this process.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Dec 25, 2010 | Plantronics Voyager PRO Bluetooth Headset
Plantronics Voyager Legend Logo
42 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
