Question about Ford Vehicle Parts & Accessories
I changed the timing belt on my 94' ranger after it broke while driving, I also changed the water pump. The timing was set back as close as i could get it. The truck seems to idle fine and drives ok(for a 94). But there is a strange sound from the engine bay, like something is rubbing somewhere near the timing belt cover. Need help please. This is my daily driver
THE TENSION ON THE BELT POSSIBLY TO TIGHT
Posted on Oct 14, 2013
2 Suggested Answers
  • 30 Answers
SOURCE: What parts should i change in order to completely do a timing belt change on an '02 mitsubishi Lancer cedia? I own a 2002 mitsubishi cedia, and i just reached 110,000 Kms and would need to do a ti
Remove the accessory drive belts. Remove the power steering pump by rotating the bolts securing it to the bracket counterclockwise with a ratchet and socket.Rotate the crankshaft bolt counterclockwise with a large socket and ratchet and remove the pulley. Rotate the bolts securing the engine mount counterclockwise with a wrench or ratchet and socket and remove the bolts and the mount...
Mitsubishi Parts
Source:http://www.ehow.com/how_7950071_change-belt-2002-mitsubishi-lancer.html
Posted on Feb 09, 2012
What is the growling noise coming from my 94 civic motor
Water pump or pulley most likely.
Always replace water pump and pulleys when you do the timing belt.
Also you may have overtightened the belt.
NOTE, Kevlar belts will make a "whirring" noise for a few thousand miles after replacement, but not a growling.
Dec 29, 2014 | Cars & Trucks
Why doesn't My truck start after changing the Timing belt on My 1999 Ford Ranger?
you need to pull the timing back apart pull the number one spark plug and role the motor over by hand to top dead center on the compression stroke the the mark for the crank should be lined up or almost lined up line it up perfect on its mark then set the cam to its mark install belt role over by hand 2to4 full rotation marks should line up perfect . install crank pulley fire it up for a split second shut it off and put it all back together
May 25, 2014 | 1999 Ford Ranger SuperCab
I'm not to familiar with these engines but it could be the crank is off one rotation. Was #1 at tdc when you set the timing marks?
May 25, 2014 | Boating
How to replace the water pump on a 1984 ford ranger 2.8 litr
I just did one on a 94 "almost identicle engine"
This is the way I did it:
drain coolant-remove upper radiator hose-loosen fan bolts '4 bolts attaching it to the water pump'-remove serpentine belt-finish uninstalling the fan- remove 2 bolts securing the fan shroud to the radiator and it should slide out with the fan-remove pump 'be sure to clean the mating surface of the block before sealing with silicone and gasket to ensure it doesn't leak'
reverse the process for installation.
NOTE: if I were you, id replace the timing belt while your in there since the timing cover is nearly impossible to get off without doing this same procedure.
Good luck.
Feb 09, 2011 | 1984 Ford Ranger
94 ranger 4cyl stopped chuggg dead is it the
check the timing belt It may have broken
May 23, 2010 | 1996 Ford Ranger SuperCab
My timing belt broke on my 1996 Ranger. It's a 2.3 5 spd - Replaced the timing belt, aligned the crankshaft at TDC before teardown and also made tick mark to align it without having to replace timing...
Is it possible that when the belt broke you may have damaged the engine (bent valve). Try advancing or retarding the camshaft sprocket by one tooth and see if that makes a difference.
Apr 10, 2010 | 1996 Ford Ranger SuperCab
Timing belt broke on a 95 ford ranger.new belt
you have to line up the two marks on the gears and set the tension to the correct setting. then check the marks again. trial and error. i just did my timing belt on my ranger haha
Feb 18, 2010 | 1995 Ford Ranger Supercab
The timing belt on my 94 2.3L Ford Ranger broke, I have replaced but don't know how to set tming
The timiing is set by aliging the timing marks on the cam with the timing marks on the crank -- then the belt goes on.
Charlie
Aug 29, 2009 | 1994 Ford Ranger Supercab
I was driving and my 94 mits expo made a loud screetching sound and my steering wheel locked up i can barley turn my steering wheel people that have looked at my car say it's the water pump what would that...
the belt that drives the water pump also drives the power stearing pump and it was locked up and not allowing it to spin fast enough for it to work or the belt broke
Jul 20, 2009 | 1994 Mitsubishi Expo
Vehicle Parts & Accessories Logo
49 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
