Question about Vehicle Parts & Accessories
I have a ford fiesta 1.4 ambient 2009 model I use a key to open the car and it only opens on the drivers door. I tried to open it but its not opening please assist I don't have a mobilizer in my car I only use the key to open it.
Spray some lubricant into the key hole and then after the inside keyhole is saturated with lubricant (WD40 for instance) GENTLY work the key in and out of the keyhole wiggling it a bit the whole time then insert the key as usual and GENTLY try to unlock it ... repeat if nessissary
Posted on Oct 15, 2013
  • 146 Answers
SOURCE: I have a 1999 Honda accord ex. my alarm wont shut off
You could first try to replace the key if that does not work the lock in the door will need to be replaced. Thanks
Posted on Jun 07, 2009
stanley141
  • 124 Answers
SOURCE: Unable to open doors with key due to discharge battery
you should not have a problem with this as the key is located in the remote and the alerm will sound but as soon as you put the key in the ignition the vehicle cancell the alarm[sword key in the remote
Posted on Jul 21, 2009
SOURCE: mgf central locking won't open the car doors
I had same problem. It was cured by "flicking" shut the interior opening handle of the drivers door. This allowed the central locking to lock then unlock the drivers door properly. You get into the car in the first place by using the romote to "unlock" and whipping the passenger door open quickly before it has a chance to relock!
Posted on Aug 13, 2009
  • 4930 Answers
SOURCE: ford fiesta ghia 1998 model central locking key
This is a common problem after changing the Key Fob battery.
The solution is to remove the fuse feeding the Cental Locking for 10 minute...Replace then all should work fine
Posted on Sep 12, 2009
logosc75
  • 625 Answers
SOURCE: I have a automatic key
Although you did not mention the type of alarm, usually the process for manaully disarming an alarm is: key on, press and release valet switch. The valet switch should be a push button located near the drivers kick panel (where your left foot would rest when driving) or, for newer alarm models,the valet switch is incorporated into the LED light or the antenna.
Posted on Oct 03, 2010
Why doesnt my G37x sedan front doors open?
2009 Door Problems - MyG37
www.myg37.com/forums/g37-sedan/253409-2009-door-problems.html
Dec 6, 2013 - 2009 Door Problems G37 Sedan. ... My problem is that my front driver side door will not open up from the inside or outside. My FOB key ... door wouldn't shut....now it won't open
Mar 5, 2015
Help! my windows roll down when i open the door!
Apr 10, 2013
Rattle in drivers side front door
Dec 11, 2010
Window Reset
Jul 28, 2008
More results from www.myg37.com
Driver's side door won't open!? - G35Driver
g35driver.com/...sedan-v36.../371407-driver-s-side-door-won-t-open.ht...
Mar 24, 2011 - I went to get in my car today and my driver's side door won't open - from inside or out. There's. ... The manual locker inside doesn't work. Problem with driver side door locking (and unlocking)
May 3, 2011
Dome light issues
Jul 3, 2010
More results from g35driver.com
Drivers door would not open - Nissan Forum ' Nissan Forums
forums.nicoclub.com/drivers-door-would-not-open-t466851.html
Dec 11, 2009 - My wife went around to the drivers side and used her key to see if she
Jan 27, 2016 | Cars & Trucks
In my 2009 toyota camry driver side door get open with remote and from in side same but other door wont open with remote and even in side switch.
It sounds like the lock connecting rod is loose or the servo is not working. Does the passenger side door open with the key? If it does, the connecting rod is OK, but the servo will still be no 1 suspect.
Mar 02, 2015 | 2009 Toyota Camry LE
Where are the fuse boxes on fiesta zetec s petrol 2009
Fuse box is located in the glove compartment. Empty the glove compartment, then the side will pop out for access to the fuses.
Aug 28, 2014 | 2010 Ford Fiesta 1.25
Doors do not centrally lock with fob or key (they close but open straight away). Onlu option is lock drivers side with key and then lock the other 3 doors manuually. Ford Fiesta Mark 6 in the UK
hi
you need to try a couple of diffrent things with this problem
1- get in drivers seat close doors and lock by hand
2- then put key in ignition and turn key till dash lights come on (do not start)
3- while key in ignition unlock doors with fob ,
4 - then lock again with fob while key in ignition.
5- then remove key exit car try locking doors from out side this should reset all your door locks
Oct 25, 2010 | Ford Fiesta Cars & Trucks
How do I open my bonnet on a ford fiesta 2000 model?? Cannot find any lever inside the car
THE BADGE ON FRONT GRILLE SLIDES UP AND DOOR KEY OPENS BONNET CHEERS
Oct 18, 2009 | 2000 Ford Focus
I have a 1998 ford fiesta 1.25 zetec s and the drivers door handle will not open.The door the door unlocks when the key is turned and can be opened from the inside could anybody please help me and tell me...
you have to take the door trim off from the inside... there is an small metal rod that attaches to the door handle with a small clip... it has come off.
Apr 19, 2009 | Ford Festiva Cars & Trucks
Ford fiesta transponder problem
I have a 2002 fiesta and recently it has been stopping on eac failure and then the imobiliser light keeps flashing and the car wont start not even turn over ha any one got a solution for this?
Thanks llinos
Nov 01, 2008 | Code-Alarm Code Alarm Transponder
Battery died now power sliding doors and rear hatch not operating
1) Unlock all doors from driver's door while it is open. The driver's door is the only door to remain open during this process! 2) Turn the key from OFF to RUN 8 times within 10 seconds, with the eighth turn ending in RUN. All the doors will lock and unlock if program is successful. 3) Turn key OFF and remove key from ignition. Within 20 seconds, press any button on the remote. (Press sliding door or rear hatch and it will open!) 4) If door locks do not respond, wait several seconds and press button again. If doors still fail to respond, try repeating steps (1-3).
Jun 16, 2008 | 2005 Ford Freestar
Vehicle Parts & Accessories Logo
13 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
