Powers off on own while printing
El2000 turns on and can start to type goes two maybe three lines then powers off ? can power on and same again... Help
    Problem Solver:
  • 10 Answers
Reinstall the cd that came with the printer, that sometimes works...
Posted on Jul 07, 2009
Hitachi 52fdx20b TV; power light will not turn off when TV is turned off.
if power light is on most of the set inside is on.
Follow power cord inside set and on power supply board look for up to three rectangular black relays that are there-----they will be marked with relay voltage in white.
Gently tap with something not metal on each until the power light goes off.
What happens is one of the relays sticks in the closed position.
If the power light goes off when you do this the relay is bad and if there are three the part number is printed on them----replace all three as they each have only 4 solder connections and are generally under 10 dollars each (wholesale about half that).
If tapping stops it sooner or later it will do the same thing again.
SD TECH
Sep 21, 2011 | Hitachi 57F710 TV
Hp deskjet d2360 power led blinking,printout also not coming. change the new catridge. same problem occuring.
Try removing and reinserting the cartridges. Remove and reinsert the USB Cable from the back of the printer. Unplug the power cord and plug it back in from the back of the printer.
If the printer is still turned off use the power button to turn it on.
There might be documents that are stuck on the queue. So in order for you to remove that.
Type services.msc on the run command if you OS is a Windows XP. If it's Vista or 7. Type it in the search box on your start menu.
Look for Print Spooler under the list of services.
Right Click on the Print Spooler, Click Stop Right Click on the Print Spooler again and click Start.
Restart the computer.
Try Printing again. ^_^
Feb 03, 2011 | HP Deskjet 2360 InkJet Printer
Motherboard beeps three times, computer won't boot up
Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
Jun 13, 2009 | Gateway 506GR PC Desktop
Lexmark x125
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Apr 09, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
