Question about RCA Televison & Video
My rlc3210 does not always have a picture. The screen goes from black to blue to snow. It also would not go to selected channel but only moves with the up or down selector.
Patrillica
  • 141 Answers
SOURCE: Picture and sound will not work all the sudden
try to clic on the input button....maybe you accidently push it ???
Posted on Apr 16, 2008
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Posted on Dec 03, 2008
  • 21 Answers
SOURCE: the screen goes complete blank with sound still
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
SOURCE: change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Posted on Oct 12, 2009
philctr1982
  • 46 Answers
SOURCE: The picture went black. The channel selector still
yes and you will be happy to know , it is a 4 dollar part , you can get from radio shack, it needs two 1000uf 16v capacitors . They are easy to replace with a sodering iron. there is a few video's on this. If you would like I could send you , just shoot me an e mail . Philctr1982@yahoo.com
Posted on Feb 09, 2010
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2017 | Televison & Video
Change channel, lose picture. power off/on, picture appears
Oct 11, 2009 | Polaroid Televison & Video
Blank Blue Screen
If you go to menu do you get that on the screen?
Nov 21, 2017 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Help
Not a home repair take it to a repair store.
May 24, 2007 | Apex Digital PF3230 32" TV
Signal Board problem
Its the tuner or the signal board and yes good call with the extended warranty. I always say on big ticket items, if your not a repairman, buy that extended warranty. Here is an article I wrote about the subject. http://www.techlore.com/article/14812/ Good Luck Ps please dont forget to rate this thread
Oct 19, 2006 | Hitachi 65S500 65" HDTV-Ready Rear...
Black screen ruining monday night football
Eliminate all other gear connected to the set and try it. If the problem goes away, you have a bad source piece of equipment. Like a VCR,DVD,etc....accordianman
Sep 27, 2006 | RCA F32450 32" TV
Televison & Video Logo
22 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
