Question about Bernina BERNETTE 65 Mechanical Sewing Machine
My needle gets stuck and its bending.I changed the needle but didn't work!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
OK. There are many types of needle. Are you using the correct one?
Is it NEW? How thick is what you are sewing? On from there, feeddog timing could be out.
If sewing 'normal' fabric, does it still have the issue?
Posted on Oct 19, 2013
Sewing and both needles broke now upperlooper gets stuck in the lowerlooper.Turning it backwards it slides by but front ways gets stuck. Can I adjust it myself or it something bent?
Ooh, that's probably something that should be addressed by a qualified technician. There are minute specifications for moving parts that need to be met and it's doubtful that could be accomplished by trying to "bend" something.
Sep 30, 2017 | Sewing Machines
What is the needle size for brothe 911 sewing machine
Be sure to change the needle frequently, ie every time you start a new project. Needles will cause a great deal of frustration yet are the least expensive item to fix.
Perhaps this will help:
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwia3-aY5LrQAhUHqVQKHUgcC5UQjBAIJDAB&url=http%3A%2F%2Fwww.schmetzneedles.com%2Fneedle-guide%2F&usg=AFQjCNG5DmrsyBAUhhGLeiVfmc4jHpjYsQ
Nov 21, 2016 | Sewing Machines
The panel lights up and then all stitches blink and there is a beep. No power and presser foot does not work.
1. Remove the bobbin and bobbin case. Try checking to see if the machine will set up without power loss.
If it stays on you need to adjust the bobbin case so it is just tight enough to keep it from spinning. Put the bobbin case in. There are screws on top of the case to loosen. Move the hand wheel each direction and see it move. The screws will allow a bracket to move to a point which will prevent the bobbin case from spinning.
Replace the bobbin. Check the tension. (See instruction)
2. While rotating the hand wheel check the bobbin to see if the needle thread moves across the top of the bobbin without getting stuck. Also, pay attention if the needle hits the sides.
3. If the thread gets stuck the bobbin case will need to be loosened about one hair strand distance.
4. If power loss is still a loss check good connection to the socket. Sometimes making a small bend will correction.
5. Check the connection to the machine. If it is loose you may need to make a very small bend on the connection. They have to be tight.
6. The same thing has to be done with the foot controller.
See attachment for tension adjustment.
Aug 13, 2015 | Singer 8763 Curvy
Change bobbin
The cheapest, fastest way is to unthread, look in all the thread 'pickup points' and make sure that there are no broken threads caught in the movement, then Rethread according to your machine's manual/diagram. If rethreading does not help, change the needle-sometimes the smallest of burrs, bends, whatever, in the needle can make a machine not work!
Feb 03, 2015 | Sewing Machines
Please help! I have a Brother Innovis 4000 embroidery machine. My machine is skipping stitches then the needle falls out or bends/breaks. This happens even after I changed the needle and rethread the...
I would double check your Threading. Make sure the thread coming from the spool is not getting caught on something. Try keeping the presser foot up, and then pull out some thread from the back of the needle, does it seem tight to pull? Now lower the presser foot, is it more difficult to pull out? It should be but not so much that it is bending the needle.
If it is to tight, there could thread caught in the tension discs. Remove the left side panel above the needle on the machine. Check to see if you can see any threads. IF not, lower the thread tension and see if that helps. Good luck
Apr 24, 2014 | Brother XL-3500
Needle hits the plate and bends. What would cause this?
try another needle and see if the needle still bends,, if the needle
still does bends then there could be something wrong with the needle
bar and the machine needs to be checked.
Nov 05, 2012 | Kenmore Sewing Machines
My needle is stuck in the plate
needle has bend remove power from mains supply and remove the needle then fit new needle
Aug 04, 2012 | Singer 2250 Tradition
While sewing, the needle suddenly hit the side of the foot-plate which bend the needle, but now the entire machanism is stuck and won't move up or down. How can I fix it and what is the cause of the...
hi there
1- how old your machine ? please check needle par play left and right or no? maybe lower needle bar bushing need to change.
2- maybe ur presser foot played need to change it but check firist.
3- sometimes when needle is broken there is small metal goes insaide the hook and make it dosn't move up or down, if you can adjust timing for hook please remove the hook and check your machine by hand move or not?
4- maybe some thread goes insaide the finger ( stopper for hook ) check this earia .
Best regards
ashraf abozid
aabozid@hotmail.com
Aug 28, 2010 | Sewing Machines
Consew 206rb bending needle
I have three possible solutions:
1. If sewing on heavy fabric or thru several layers, change needle to a larger size.
2. Make sure to let the fabric feed by itself, don't pull on it.
3. Make sure the upper thread is not catching on something (like the end of the spool), this will cause the needle to bend and break.
good luck!
Jan 30, 2009 | Consew 206RB
Bernina BERNETTE 65 Mechanical Sewing Machine Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
