Question about Hardware & Accessories
Ls430 malfunction indicator lamp stays on during driving mode.
    New Friend:
  • 17 Answers
Sounds like you need to take it into a local repair shop and have them hook it up to a diagnostic tool to find out the problem.
Posted on Nov 12, 2013
Push button for four wheel drive isn't working
Do you have any lights on the dash lit ?
SERVICE indicator (4WD/AWD) Lamp
The SERVICE indicator (4WD/AWD) lamp is an integral part of the cluster and cannot be serviced separately. This lamp is used to inform the driver of the vehicle of malfunctions within the automatic transfer case (ATC) system. The SERVICE indicator (4WD/AWD) lamp is controlled by the transfer case shift control module via CKT 1567. this system will set DTC'S if there is a problem .
Diagnostic Trouble Codes DTC B2725 ATC Mode Switch Circuit Malfunction DTC C0300 Rear Speed Sensor Malfunction DTC C0305 Front Speed Sensor Malfunction DTC C0308 Motor A/B Circuit Low DTC C0309 Motor A/B Circuit High DTC C0310 Motor A/B Circuit Open DTC C0315 Motor Ground Circuit Open DTC C0323 T-Case Lock Circuit Low DTC C0324 T-Case Lock Circuit High DTC C0327 Encoder Circuit Malfunction DTC C0367 Front Axle Control Circuit High DTC C0374 General System Malfunction DTC C0376 Front/Rear Shaft Speed Mismatch DTC C0387 Unable to Perform Shift DTC C0550 ECU Malfunction DTC C0611 VIN Information Error you probably should take this to a repair shop !
This tt
Feb 22, 2015 | 1999 Chevrolet Silverado 1500
Malfunction Indicator Lamp
If you are not experiencing any running symptoms, you should be ok but take it in as soon as possible just in case it is serious which may end up costing more if you wait too long.
Dec 26, 2013 | 2003 Volkswagen New Beetle Convertible
Mini Cooper S Engine Management Light
The following are descriptions from the Mini-Cooper S owner's manual.
Service Engine Soon "?If the warning lamp comes on
either continuously or intermittently, this indicates a malfunction in the emissions-related electronic systems."
EML light: "Engine electronics ?Malfunction in the engine electronics. You can continue to drive with reduced engine output or engine speed."
Triangle circled by an arrow: "Automatic Stability Control plus
Traction (ASC+T)/Dynamic Stability Control (DSC)
?Indicator lamp flashes: System active: drive and braking forces are regulated.
The indicator lamp stays lit: ASC+T/DSC switched off with button or defective. In the event of a defect: please have the system inspected at your MINI Dealer."
First, inspect the belts to make sure none failed at high RPM. If one broke, inspect any cable or hoses in the plane of the belt to see if there was any damage (e. g., a ripped wire in the ASC+T/DSC system). Second, get a readout of the engine error code. (If you get indications of a major vacuum leak including rough idle, look for a blown head gasket.) If you get something else, please post the results in a comment so we can go to the next step.
Jul 09, 2017 | Mini Cooper Cars & Trucks
Check engine light is on and my car hesitates when accelerating. Sometimes the check engine light will blink (instead of just stay on steadily) during moments of hesitation/acceleration.
When a 'check engine light' (MIL=Malfunction Indicator Lamp) is turned on, there is a DTC (Diagnostic Trouble Code) set/stored in the ECM/PCM (Engine Control Module/Powertrain Control Module). This code identifies which engine management system component/function experienced a malfunction. Once you pull/read this code, you may begin diagnosis.
Aug 14, 2011 | 2005 Hyundai Accent
Malfunction Indicator light
usually a sensor has gone bad. have it check by a mechanic on the computer.
Mar 29, 2010 | 2003 Subaru Forester
98 LEXUS 400 DIDN'T WANT TO START, WHEN IT DID IT HAD NO ACCELERATION & THE MALFUNCTION INDICATOR LAMP & vscOFF INDICATOR STAYED ON. RESTARTED & RECEIVED ACCELERATION BUT WARNING LIGHTS STAYED...
You need to get the codes from the computer to know where to look. This could be a simple O2 Sensor and on this model vehicle the ECM will go into fail safe mode that will let you drive it to a service location for repair. The stored code will tell you which it is and what you need to look at for a repair.
Oct 09, 2009 | 1992 Lexus ES
Check your CAPS LOCK as that may be the problem.
Sep 13, 2009 | 2002 Honda Accord
2000 Toyota Platz malfunction indicator lamp stays on
let me tell you its solution....:)
do check all filters and engine oil...
if it still remains then replace its battery ...
its all done
Jun 19, 2009 | 2000 Toyota ECHO
Malfunction indication
The Malfuntion Indicator Lamp (MIL) is being lit up by the vehicle's computer to indicate there is a problem with one of the vehicle's systems.Have the vehicle scanned,write down the code number and definition,and ask whoever scans it what's involved in repairing the malfunction,and what system it is in.Or come back in here with the code number and definition,and we can help you.
Jul 10, 2008 | 2003 Nissan Pathfinder
Malfunction Indicator Lamp (MIL)
I had the samething happen to my Jetta. I took it to the dealer and nothing was wrong.
I would think it's safe to drive until Monday when the VW shop opens.
My 2 cents
Jun 14, 2008 | 2007 Volkswagen GTI
Hardware & Accessories Logo
19 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
