Samsung VRT washer and the door will not lock hence the machine will not run. Have looked up the model # to get replacement part for lock and cannot find model or part?
    Top Expert:
  • Washing Mach... Master
  • 44,089 Answers
Don't know where you "looked up" the information, but Samsung should be able to tell you what you need. You also might try an appliance parts supplier
Posted on Oct 14, 2013
  • 3 Answers
SOURCE: Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Posted on Jan 18, 2008
SOURCE: Door won't open on Samsung washer
This has happened to me twice. Both times I found the drain pump seized up with
1st time) The right rim from a pair of reading glasses
2nd time) A plastic toothpick
Both times the object was in the discharge port of the pump. You can see this by lifting the check valve with the pump removed. Removing the pump is simple. Unplug the washer. You have to remove the drain line from where its attached to the rear of the machine (one screw) to remove the rear access panel which slides into upper and lower slots. You will see the pump with an inlet and discharge line attached. The lines have simple squeeze clamps. When you remove the lines, you will drain the wash basin so have towels and a squeegie handy. Remove both lines and wait until the basin drains. When it stops draining remove the pumps electrical connector by squeezing the release catch on it while pulling it. The connector can only go on one way. Remove the 3 hold-down bolts on the pump baseplate. Remove the pump and lift open the discharge check valve and you'll find something there I guarantee it. Remove with needle nose pliers and re-assemble in reverse order.
This is actually a good design because the computer protects the pump by sensing a higher than normal current draw when foreign debris gets jammed in it. It will trigger the ND (No Drain) code and sometimes lock the door. Always check this first before you call the expensive repair man. If its not a jammed pump it will most likely be the control panel/processor. Good luck and always clean out pockets before loading the washer to prevent this,
Posted on Feb 14, 2009
SOURCE: filter
I have a vrt ... I hope this helps.... Take of that little door on the front. Have a bucket or bowl ready. Bring down that little black hose, turn the white cap around and pull till it comes off. Drain into the bowl, turn the white filter cap counter clockwise to release some of the suction and wait till the hose stops draining. Remove cap, clean under running water w/ toothbrush. Manual says to make sure that the interior is free of anything (I wiped mine out) and then put it all back together again. Good luck
Posted on Sep 03, 2009
SOURCE: Considering the purchase of Samsung WF338 / DV338 Washer & Dryer
Don't buy any Samsung products. They're definitely not worth the money. We bought the front load 2009 washer and dryer about 14 months ago. Have always had problems with the dryer -- auto dry is a joke. The washer will not allow you to change the water temp. It's supposed to automatically correct the water temp; what a joke. AND the power went off today while the washer was filling with water, with clothes in the tub. No way to open the door, and we have to wait almost a week for a service call!!! IF YOU BUY SAMSUNG PRODUCTS, YOU WILL BE WASTING YOUR MONEY!!!
Posted on Aug 01, 2010
trhall71
SOURCE: samsung vrt front load washer will not spin out, ( not working)
I have the same washer and mine wouldn't spin out all the way sometimes leaving the clothes very heavy and wet. My problem was that the drain hose from the washer that you put inside your drain pipe had created a suction preventing it to drain properly. It might be worth checking. I know for forking out so much money on the thing it sure can be finicky.
Posted on Apr 18, 2012
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
Cant get washer to unlock
The door lock has failed and will need to be replaced.
Jul 20, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Feb 23, 2015 | Samsung 3.7 CuFT VRT Front Load Washer
Samsung front load washer door will not lock
Hi
Are there any error codes on the display
Regards
Phillip
Dec 25, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Samsung VRT with a DS or D5 code? Door closes but won't lock
bad door lock switch mechinism or the control board is bad at the emergency door lock circuit? where the wires from the door swtich attache, check ur schematic and will need a multimeter
Dec 18, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Fl error code
The "FL" code indicates that the unit failed to lock the door, which would prevent the machine from running. If this happens again, close the door tightly and restart the cycle. If the code reappears, your washer may require service. What is the model number?
Nov 02, 2012 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung vrt fl code
Check both parts of the latch mechanism. Something may have gotten stuck or the latching device may have broken
Sep 08, 2012 | Samsung WF337AA Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
