Question about Ovens
I have two problems with my zanussi single oven zyb 594 firstly i replaced the bulb which had blown inside the oven with the correct bulb but still isnt working. secondly the cover on my fan the tork screws seem to be loose and corroded is it possible i can buy some news or something very similar thanks you if you can help.
SOURCE: Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Posted on Jun 22, 2008
  • 11 Answers
SOURCE: Inside glass of zanussi oven
Works on Zanussi ZBF 660 X Built In Oven.
To remove door:
Not sure if you still need to get your oven door off still but I have the same oven and have spent the last several hours trying to remove it and searching the web to discover how to remove it until I have just discovered a wonderful video tutorial on YouTube www.youtube.com/watch?v=hSzc4Uqbbr8
that discribes exactly how to do it (just copy and paste it into your address bar.
It is the fourth and final instruction in the video but it really is easy.
The hinge is a latching over system type that folds back into the glass apparently.
Just get a screwdriver and where the end of the hinge dissappears into the housing of the oven just flick up the hinge with the screwdriver and the locking mechanism folds back towards you and the glass.
Once both are done just jiggle and pull up the door and it will remove easily....godsend!
Regards,
DIYDIM
Posted on Dec 05, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
SOURCE: unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Posted on Feb 28, 2010
SOURCE: After using the self cleaning
If you slide your oven out and take off the center panel on the back of the oven you will see the thermal fuse. If it's like mine, it will be located (looking from the back of the oven) upper right hand side. It's an oblong loooking part with two terminals with wires attached to it and two screws holding it on. Once you take it off, you will notice that it is flat on the back side and you should be able to see part # 9759242. Only reason I know this is that I have just removed mine and am going to see if I can find one locally. Same thing happened to mine after putting it in the cleaning cycle to clean up after the holidays.
Hope this helps!
Robert
Posted on Dec 27, 2010
Why wont my bottom oven heat up, it will ignite but wont heat,has the bulb anything to do with it,its blown HELP ZANUSSI ZCG660GXC LPG gas with electric ignition and clock.
The gas valve for the lower oven won't open after the igniter starts glowing. If there is no orange glow from the igniter, then it needs to be replaced.
Jun 19, 2015 | Zanussi Ovens
My zanussi oven blew, I changed element still not working, seems my bulb blew 2 and connection as I taken it out, would this stop the circuit from working as I have no power to cooker and switches ect are...
When the element blew , it may have taken out either the selector switch or possibly the toc, if the bulb has blown the oven should still heat up .
Mar 06, 2015 | Zanussi Ovens
Replace light
The instructions state:
1. Ensure the oven is disconnected from the electrical supply.
2. Turn the glass cover anticlockwise.
3. Remove the faulty bulb and replace with the new one.
4. Refit the glass cover.
5. Reconnect to the electrical supply.
Jan 09, 2014 | Zanussi ZBF360 Electric Single Oven
Zanussi oven zbf 360 + bulb blows repeatedly
bulbs blow from incorrect voltage in use or loose ground wires ( arcing out)
if they fail while the oven is on it is because the bulb construction glass is wrong
bulbs used in ovens need a special heated treated glass and are generally only available from the service agent
failing immediately on turning on indicates a bigger problem that the bulb so call in an electrician to test the system
Mar 24, 2017 | Zanussi ZBF360 Electric Single Oven
The element has blown on my Zanussi ZBF860 oven. I
You should be able to remove the element without removing the oven. Open the door and remove the back panel, normally 4 screws. This will expose the element. Then it should be 3 or so screws holding the element to the frame, remove these and slowly pull the element towards you carefully, then remove the 2 wires from behind and make sure they don't fall back into the oven as you will need to remove the back panel to get them. Then reverse process to install new element. Hope this helps.
Mar 15, 2011 | Zanussi ZBF360 Electric Single Oven
How do i change the light bulb in a Zanussi oven ?
Turn off at the wall and remove the light cover inside the oven by turning anticlockwise, this may be stiff, I use a well wrung out dishcloth.
You can see the bulb, which should be screwed out of its holder with care, also care when replacing. a I screwed mine in too hard and snapped the holder, but my oven is 5 years old.
Hope that helps
Jan 01, 2011 | Zanussi ZBF360 Electric Single Oven
The oven light stopped working so i replaced it but it still does not work although the oven works, I have tried opening and shutting the door a few times but this does not work either
I would first of all try another bulb, if that does not work, then could be a faulty door switch, or bad contacts in bulb holder.
If you can access it, then disconnect the 2 wires going to the door switch and join them together, this will prove if the door switch is faulty, or if there is some other fault.
Dec 28, 2010 | Zanussi ZBF360 Electric Single Oven
I don't know what wattage I need for the bulb
You can fit a 15 or 25 watt bulb, as long it it is the correct thread, and it is able to withstand 300 degree temperature.
This is very important, otherwise it will blow with the heat.
Hope this helps.
Jan 20, 2010 | Zanussi ZBS963X Electric Single Oven
The bulb seems to have fused. How to remove the fused bulb and replace with a new one. Have I got to pull the oven out and fix it from the rear?
No, you should be able to replace it within the oven space. The cover should unscrew and reveal the bulb which you then remove and replace.
Jan 19, 2010 | Zanussi ZBS963X Electric Single Oven
I can not get the glass cover off to replace the bulb. What should I do?
these turn anticlockwise this might be helpful We have a Free full video library on appliance repair video’s
and if you need bulbs
Jan 13, 2010 | Zanussi ZBF360 Electric Single Oven
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
