Brother TN350 - Toner Problem
The toner in our Brother TN350 Fax machine is leaking and causing the printed copies to be full of ink.
  • Hilsrus Feb 26, 2008
    I refilled my Brother Laser fax TN350 toner with a replacement toner kit. The toner light had been flashing. I installed a gear and filled the toner with the new product. Toner was coming out of the unit and blobs on the pages. I completely emptied the toner and refilled it with another container of toner. It is somewhat better but I still get lines down the middle now. I'm sure it was a case of overfilling.
    Sergeant:
  • 361 Answers
It shouldn't leak, replace it immediately if that's the case and next time try to follow the instructions properly.
Affordable Brother TN350 Toner Cartridge
Posted on Jul 01, 2018
    New Friend:
  • 120 Answers
The toner is n/g. replace it if it leaks.Lawrence
Posted on Feb 16, 2008
SOURCE:
Replacement toner cartridge not accepted
I Suggest You To Watch just replaced the toner cartridge and the LCD continues to Brother To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jun 11, 2012 | Brother Toner Cartridge Tn350 for MFC7420...
I am changing the ink cartridge i put the new one in and it keeps saying End of life and it has a new cartridge what do i do
Here is the solution that will reset the count and allow your fully functional toner cartridge (the one the printer tells you is empty) to continue to work.
Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.
You have to do this with a long pause or the system will reset and you will have to start over.
Good luck.
May 24, 2010 | Brother DCP-7020 All-In-One Laser Printer
How to change the ink toner ?
Go to the Brother web site and download the user guide. You'll find all the info you need there.
Sep 13, 2009 | Brother IntelliFax-2820 Laser Fax
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother intellifax 2820.Replaced toner cart tn350.
Remove drum unit. in front of the toner cart. there is ether a green or blue slide lever. move the slide 10-15 times back and forth. make sher the slide is all the way over to one side. reinstall drum & make a copie. hope this works.
Jan 05, 2009 | Brother IntelliFax-2820 Laser Fax
Fax prints to dark
have you replaced the drum??? are you using brother oem toner???? generic toner will give you all kinds of problems
Oct 29, 2008 | Brother IntelliFAX 2800 Laser Fax
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Open Questions:
327 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
