Question about LG Televison & Video
Tv won t change channels
I have a Lg lcd flat screen 1080p. The problem is that its stuck on one channel. It doesn't work with remote or the tv button. everythging else works. what can the problem be? thanks.
    Problem Solver:
  • 17 Answers
Call a pro
Posted on Oct 14, 2013
ginko
  • 19396 Answers
SOURCE: TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
Posted on May 16, 2009
romsky79
  • 822 Answers
SOURCE: Channels will not change- 42
it means that only one channel save from your tv. press automatic search to search more channel from cable signal. now you can change channel.
Posted on May 29, 2009
SOURCE: ''Select DTV channel for OAD'' screen and can't remove
**This is NOT a solution**
I was wondering if you were able to fix this on your own. I am have the exact same issue with a 42LG30
Posted on Dec 07, 2009
  • 4 Answers
SOURCE: New Vizio TV - Channel up and down buttons don't work
upon the psp and try to fix it
Posted on Apr 10, 2010
vinceisaac
  • 2432 Answers
SOURCE: My son is in Stanley
hi the problem with your tv is with in button key controller board, here are the ways on how are you going to fix the problem.
  • open the back cover of your tv with the use of philip screw driver to gain access the button controller.
  • remove the connector and then detached the controller board, spray the channel up/down button with a electronic contact cleaner to have good contact.
  • if the buttons are worn out you can replace only the buttons just buy at any electronics store, you can also buy or replace the whole button key controller if you want. there are sites in an internet which provide button key controller for tv like for example you can inquire here.
  • now after you replace with new button controller reinstall the connector fix it not to loose and then placed the back cover of the tv unit and screw it.
  • plug the power cord then turn on the unit. good luck i hope it will help you.
Posted on Jun 10, 2011
Testimonial: "Thank u so much. If this works it will save us so much money. I'm disabled and live on a very limited income. Thank u. Thank u. Thank u."
My lg tv is stuck on chnnel 7. I can't change the channels.
try changing the channels from the tv buttons and not the remote control and if that works your tv has a faulty infra red remote sensor which is easy to replace if you can use a screwdriver
Sep 29, 2014 | LG 32LG30 32 in. LCD HDTV
My westing hous hdtv is stuck on channel 35-3 and will not switch to another channel, the remote doesn't work and neither do the buttons on the side of the tv, the power button works but won't
Try to unplug power from set for a while and plug back to reboot--immediately delete that channel from the set's memory as it may contain signal that is causing this.
Also look to see if the set has a feature to lock out the buttons and or the remote control---a few do.
Most likely something in the signal for that set caused the set to lock up.
Sep 02, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Insignia lcd won't change channels
on the off chance read the owner manual as the set may have a feature that locks the keyboard and the remote out
Aug 27, 2012 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
LCD 42 LG TV won't change channels with channel button only with numbers
First check with fresh batteries. that does not resolve it If a universal remote- try a different code. If original remote, press the "TV" button first to make sure it is using the right parameters. If still not resolved, the issue may reside in the IR circuit of the set.
Dec 31, 2011 | Televison & Video
My LG LCD TV cant stop changing channels on it own . I ve removed the batteries from the remote but still its changing them on its own
Is it going one way - channel 1-2-3-4-5 bottom to up or any way at random. Find out which way and check the channel button on the TV to see if it is stuck.
Mar 17, 2011 | LG 37LD450 37 in. TV
Cannot turn tv off with power button or remote , must unplugpower
It could be a stuck button on the set. check to make sure they all feel the same.. If one don't feel right try to free it .. If a button is stuck it wont let any of the others work or the remote.
Mar 29, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Televison & Video Logo
536 people viewed this question
Computer Repairing
Computer Repairing
