Question about Ovens
Lots of information about tornadoes that are in handy
Tornado turbo chef Oven give f3 fault after16 secs
the most complicated error for this oven ... this error affects ur micorwave system .... this requires a tech to check ur unit
Sep 05, 2014 | TurboChef TORNADO Electric Oven
Turbochef Tornado EC cooling fan ALWAYS runs at full speed
What jim said is right. plus clean the front vent. take off bottom front panel and clean all the little round holes. also if its dirty inside everything runs hotter(which makes the EC get warm faster) and dirt gets on the little wire(it's about 4" long coming from the main 40 pin connector0 that monitors the EC temp(clean it). sometimes the fan starts to get weak and doesn't cool properly. also, unplug oven, take side panel off and clean it as well. there are vents on it that get clogged. while it's unplugged clean the inside. I use a paint brush and shop van. just be careful not to hit wires or knock wires off. this will all help a bit but that fan will still run a lot anyway.
Apr 21, 2014 | TurboChef TORNADO Electric Oven
Can u cook air fried chips in the turbo.tornado oven
Yes any thing that is not greasy as it will block the catalytic converter
Jun 02, 2012 | TurboChef TORNADO Electric Oven
TurboChef Tornado is showing error Close door P _ _. How do i fix this?
The primary switch is broken most likely. Take off the right cover and look past the control board and see of that switch is broken. its only a couple dollar part.
Jan 20, 2012 | TurboChef TORNADO Electric Oven
F7 code
HELLO the F7 fault code means that you have opencircuit in the , ir thermocouple which is in the bottom element or the thermocouple for the top cc element,
May 02, 2010 | TurboChef TORNADO Electric Oven
I have both a tornado and a C3. I am getting a F2
for the f2 low temp verify the high-limit thermostat is not tripped. inspect the mags, make sure they are not loose. Also try inspecting the ir element washer look for corrosion or signs of arching. Is your wave cover damaged or missing. Sorry to say this generally is a factory trained fix because its usually because of an rf leak
Oct 09, 2009 | TurboChef TORNADO Electric Oven
This is the 3rd time for this turboChef oven - door not closed.
it is because the switch kits are not setup properly.they need to set to open and shut in the right order,hope this helps regards lse
Jan 16, 2009 | TurboChef TORNADO Electric Oven
Ovens Logo
11 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
