Question about Hobart C-100 10 Quart Mixer
Hobart C-100. Yep, we pulled off the shifter handle to replace the switch and the key fell in. I've seen a few brief answers...but since it seems to be a common event, how bout some step by step advise on how to pull the trannie and replace it - think like a newbie!!!
4 Suggested Answers
  • 110 Answers
SOURCE: hobart c-100: how to remove gear shift plate???
parts are almost obsolete for that mixer
Posted on Jan 09, 2010
  • 110 Answers
SOURCE: hi somenone may describe how I can procede step
after you removed the tapered pin on the plant. you should be able to get it off the mixer main shaft @this point, there is nothing else holding it to the main shaft
Posted on Jan 16, 2010
Hobbit_who
  • 2044 Answers
SOURCE: Older, (1950) Hobart A-200 runs in first gear no matter where the shifter is set?
My Hobart had a switch on the side to change Gears... 3 Different Speeds
Posted on Apr 11, 2013
Apr 11, 2013 | Hobart Food Mixers
I just bought an old Hobart mixer....All the
www.hobartservice.com enter your zip in "locate an office" it will bring up your local Hobart office.
May 16, 2010 | Hobart D300 Stand Mixer
Hobart D340 mixer will not hit 3rd gear
Check that the gear on the shaft that the clutch gear engages with does nort have a sheared key.
Feb 12, 2010 | Hobart D340-6007 Mixer
My Hobart mixer is hard to start. I have to keep
take off the side cover where gear shifter is, you probably have the original arrow hart contactor in there ,that part is obsolete but you can get a kit from hobart to upgrade the control circuit
Nov 29, 2009 | Hobart H600 Stand Mixer
Hobart c-100: how to remove gear shift plate???
Oct 02, 2009 | Hobart A200 Stand Mixer
Mixer speed selector lever
Hi. I live in Canada. I called my Hobart Parts people and they tell me that your shifter is obsolete and the shifter is no longer available in North America. I have the same model as you. For your information, the Specifications # is 3943 and your mixer was manufactured in 1966. Your serial # is 1648855. The age of your unit pre-dates the ML identification numbering system.
The newer shifter you speak of is not compatible with your machine as hobart also made transmission changes when they built the newer model. It will not mate with your machine, so save your money and don't buy the new one. Your shifter lever is made of Aluminium.
You have 3 options.
1. Check around the Wholesale Restaurant Equipment places if you have any nearby and see if they have the part you're looking for. Often times they keep some of the old parts from obsolete machines that they can no longer repair.
2. Find a local welder who can weld on a short piece of aluminum to the remainder of your shifter or if you have the piece that broke off, weld that back on.
3. Search eBay.com for the original part. There are many thousands of these mixers still in use, and you might get lucky and find the lever.
If you found this solution helpful, please rate it as fixya. Good luck! ricardok45
Feb 02, 2009 | Food Mixers
Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
Jan 15, 2009 | Hobart A200 Stand Mixer
95 year old hobart mixer: two pole single throw switch
Im a tech for hobart and have seen old mixers but not that old.Hobart wont have parts but you could goto an electrical supply place,take the switch and ask them for something universal.
Dec 16, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart C-100 mixer HELP!!!!
This is common there is a key on the shifter shaft and when you removed it the key came out and is floating in the grease in the tranny ready to destory the gears. That are no longer available at Hobart. if you want the shifter /switch plate off, remove the pin in shifter and the handle thats all. Hobart has a special puller I have two of them but you can use a H type puller to get to the pull threaded holes Mixer should be upside down on head to repair trans.
Apr 02, 2008 | Hobart A200 Stand Mixer
HOBART D 300,SERIAL NR. 94.819 808, ML NR.116 12
hi i work for hobart and these part numbers dont sound right.you have to make sure you have the ml number or spec number to get the correct parts.you can call your local hobart branch and they will help you further.
Oct 21, 2007 | Hobart D300-6036 Mixer
Hobart C-100 10 Quart Mixer Logo
102 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
