Cannot open the cap to get wayter in - Computers & Internet
    Problem Solver:
  • 12 Answers
Push down while turning to the left...do not do this when the car is hot
Posted on Nov 13, 2013
Open gas cap on 2013 Buick lacrosse
This should be a normal threaded cap and will twist off in a counter clock wise motion. If the cap is not original and has been replaced with a locking type cap, it will require a key to unlock it and the removal procedure will be the same as the original cap
Jan 29, 2016 | 2013 Buick - LaCrosse
How do I get gas cap off?
try applying the pressure with water pump pliers if you have the room to work with them around cap
Jun 28, 2014 | Electrical Supplies
Code # PO446
P0446 Nissan - Evaporative System Canister Vent Control Valve Circuit
Possible causes - Missing Fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Vent control valve harness is open or shorted
- Vent control valve circuit poor electrical connection
- Faulty vent control valve
Tech notes Before replacing any parts, try re-tighten the gas cap and clearing the code. If the cap or cap seal is damage replaced cap and clear the code.
Apr 12, 2014 | Nissan Pathfinder Cars & Trucks
P0446
P0446 HYUNDAI - EVAP Emission System Vent Control Valve Open Circuit
Possible causes- Missing Fuel cap
Dec 20, 2012 | Hyundai Motor 2003 Sonata
How do i connect a salt water system to the pool
if you use a salt system in an above ground pool, the steel frame work will last less than 2 years before it rusts out
talk this over with the pool experts first and then have them help you with the system needed
Oct 25, 2017 | Intex Automatic Salt Water System for ...
HOW DO YOU OPEN THE GAS TANK CAP ON A HARLEY 2008 SPORTSTER?
As far as I know, it opens the same way any other gas cap opens. Twist it in the counterclockwise direction. However, the bike may have a custom style gas cap installed on it. Evidently this is a previously owned bike that you have because I'm sure it's need fuel in it since it was first sold.
Aftermarket caps come in all types. One of the most popular are the flush fitting aircraft type caps. These open by pressing them downward and releasing the pressure quickly. The cap will jump up allowing you to take it off.
Good Luck
Steve
Nov 06, 2010 | Harley Davidson XL 1200 C Sportster Custom...
Every few weeks, my 4-cup Starbucks Barista Quattro coffee maker overflows. It seems that the water either flows into the basket too rapidly or out of the basket too slowly. The basket overflows, and...
If your in a hard wayter area the basket overflow valve may be need cleaning. Fill with white vinegar and run a full cycle. Rinse by running 2 or 3 cycles with clean water. You may need to repeat the vinegar cycle if the problem persists.
Oct 16, 2010 | Starbucks Barista Quattro Coffee Maker
Need installation advice
All caps are designed to be wired in parallel with another cap if desired. The three openings work to daisychain caps, positive to positive and neg to neg, the third connects to ground on the negative side and 12v+ on positive. You do not want to ground multipule caps individually. You can add as many caps as you can afford!
May 05, 2009 | Car Audio & Video
1994 Chevy Silverado Gas Cap Unavailable?
Autozone or oreily just any gas cap just about will do. To force open use a flat head screw driver, hammer and pliers. Drive the FLAT tip screw driver into the gas cap and use the pliers to turn. These vehicles did not come factory with locking gas cap so some one has replaced it once before. Don't worry the worst you can do is ruin the gas cap which is no good to you any way.
Apr 29, 2009 | 1994 Chevrolet Silverado 2500
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
