Question about Drills
Hilti TE60 30Yr old. Motor seized, suspect bearings gone. Where to get it repaired.
3 Suggested Answers
TX_AC_Man
  • 107 Answers
SOURCE: Need new fan motor.
If you are mechanically abled you could remove this motor and go match it to a new one at a local electrical supply house that carries motors. Let me know if you go that route and I can get more detailed for the process.
thank you
Posted on Sep 05, 2010
  • 414 Answers
SOURCE: The drum on my wf860 is very stiff and difficult to turn I suspect the bearings have gone what is the average cost of replcing bearings by engineer, the machine is about 7 yrs old so it maybe cheaper
I think hotpoint do a set fee all in charge, give them a call to verify, otherwise you are looking at the best part of the cost of a new machine and at 7 years I would recommend a replacement rather than repair. At least you know you have a waarranty, Bosch are offering 4year manu garauntee on selected machines at the moment (in the UK)
Posted on Nov 23, 2011
Hi. I was drilling a few holes in concrete with my TE 56 HILTI and the drill bit become jammed. it began to smoke so i put a new set of brushes in it and still the same spins slow and smokes, any...
It sound like is has overheated or a bearing has seized. Take it to hilti. www.hilti.co.uk for nearest dealer. They will collect for a price.
Dec 11, 2012 | Drills
Bosch Prio Sander failure
The screeching was indeed the sound of a bearing seizing, however now that the motor is running freely it means the bearing is in fact seized and burned up the plastic that holds orbital mechanism. Its possible to diy, you'll have to open it up to see what damages that bearing created. Hopefully you still have a warranty...
Nov 30, 2017 | Tools & Hardware - Others
Replacing brushes on a hilti te 7a 36v cordless hammerdrill
the fan probably exploded and you would need to replace the motor assembly. You can contact HILTI direct at 1-800-879-8000 for parts and breakdowns.
Jan 26, 2012 | Hilti Drills
The carbon brush gone i need a replacement
Here is a detail part list from Hilti.
Link HERE to open the drawing and part list.
Please bookmark this page for reference.
The item in question is carbon brush.
This is inter-grade inside item 2 (the electric motor).
Hilti has a life time warranty on labor and two year in parts.
This model was introduced around March 2009.
Check the model plate for production date.
Contact you local Hilti rep to send the unit for free repair.
Act now to avoid the labor charge (2 year FREE labor)
In most case you can use the manufacture t oprove the unit is under 2 years old.
A sales order or receipt of this Hilti SFH 18A will help speed up the repair process.
Additional references
Hilti, Inc.
5400 South 122nd East Avenue
Tulsa, OK 74146 Phone: (800) 879-8000 Fax: (800) 879-7000 Espa?ol: (800) 879-5000
Feb 01, 2011 | Hilti SFH 18A CPC Hammer DrillDriver
The drill is leaking oil
As my knowledge drills not use oil just grease in the bearings.But if you need to service and the drill is not too old and the repair is not cost too much you can find parts at Hilti Online or by your self using the Hilti Manuals.
Nov 11, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Need brushes for an old style hilti te17
Hilti should be able to provide you with them. If not contact a local motor repair outlet and find brushes the same size, they are very easy to change on the TE series.
Failing that Hilti offers a trade-in program for their tools.
Dec 31, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Blower fan is seized Kenmore 54501 Dehumidifier?
If the blower motor is siezed up, then you need to replace the motor.
You can have new bearings put in it, but by the time you get thru it will cost you about the same as a new motor and you won't have any warranty on the old motor, you will have at least a one year warranty on the new one.
Aug 09, 2009 | Kenmore 54501 Dehumidifier
I have a Hilti TE 905 AVR the service light came on and it stopped working. Is there a troubleshooting guide to fix and reset this. Also, schematics can be found at:...
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Jul 08, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
How to dis-assemble motor housing.
Not outside my category list. Its a Hilti, not Hitachi, right? They are a tad tricky. Best thing is to go to Hilti.com in the tech center. Click Tech Center and then Tool Schematic list rotary/combihammers. Get the breakdown. there should be four screws that detach it from base, hard to see. May need allen wrench, can't remember. The fan comes off the armature, may also need small bearing puller. hope this helps. Please rate me
May 23, 2009 | Hilti Drills
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Drills Logo
69 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
